mrbigsacks Posted September 16, 2009 Report Share Posted September 16, 2009 whats going on guys? anybody heard of crank seals causing starting problems when cold? when it's warmed p it kicks over. also takes while to come down to idle after reving it. thanks. 99 banshee Quote Link to comment Share on other sites More sharing options...
mrbigsacks Posted September 16, 2009 Author Report Share Posted September 16, 2009 aright from the top new choke, tube in place float set,carbs clean jetting close, seems like it has air leak somewhere leaning it out. whon't kick cold spay carbs with gas fires right up, after it's alittle warm kick on it's own.any help would be great thanks guys Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 16, 2009 Report Share Posted September 16, 2009 Have you done a leak down test yet? Quote Link to comment Share on other sites More sharing options...
mrbigsacks Posted September 16, 2009 Author Report Share Posted September 16, 2009 Have you done a leak down test yet? not yet, going to take to a shop can't deal with it anymore just wondering if it could be the crank seals. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 16, 2009 Report Share Posted September 16, 2009 (edited) Well whens the last time you put some seals in? If there real old yes it can suck air in and cause a lean condition and idle high IMO you should just build a leak down tester real quick for $30 and just check and see if you have an air leak some place. Or at least start the motor and spray soapy water all over the motor, carbs and intakes. If there is bubbles, there is your leak. How to build a leak down tester quick>>>> http://bansheehq.com/forums/index.php?showtopic=110585 Edited September 16, 2009 by savage420 Quote Link to comment Share on other sites More sharing options...
mrbigsacks Posted September 17, 2009 Author Report Share Posted September 17, 2009 never put seals in it might build tester if I feel spunky thanks for the info Quote Link to comment Share on other sites More sharing options...
