cjcrete Posted September 13, 2009 Report Share Posted September 13, 2009 Has anyone here ever seen a banshee with reverse cooling? JSR produced (i thing about 8 or 9 of these motors) These motors claim an extra 7-9 hp over convensional banshee cooling! Quote Link to comment Share on other sites More sharing options...
shogs Posted September 13, 2009 Report Share Posted September 13, 2009 I dont see how cooling can effect hp, especially by 7-8 hp. The words Reverse cooling don't even make any sense to me. Quote Link to comment Share on other sites More sharing options...
cjcrete Posted September 14, 2009 Author Report Share Posted September 14, 2009 I dont see how cooling can effect hp, especially by 7-8 hp. The words Reverse cooling don't even make any sense to me. Maybe loboboy can chime in here, Stallworth does some crazy stuff. I guess all the new yzf yamaha's cool this way now. I hope someone has more info than i? Quote Link to comment Share on other sites More sharing options...
Powerstroke Posted September 14, 2009 Report Share Posted September 14, 2009 I dont see how cooling can effect hp, especially by 7-8 hp. The words Reverse cooling don't even make any sense to me. Reverse cooling simply means the cold water goes to the head first. Its been used in the automotive world for a while now. No idea if it is being used in the atv world. Quote Link to comment Share on other sites More sharing options...
superfastyfz450driver Posted September 14, 2009 Report Share Posted September 14, 2009 arctic cat did a reverse cooling system on the 03 and up firecat f5, f6, f7 sleds the whole reason for the reverse cooling was to be able to allow for more advanced ignition timming without detonating, its a real good system but the firecats are a pain in the arse to bleed the air out of when filling up the cooling system Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 14, 2009 Report Share Posted September 14, 2009 The coolant does go through the head first. It is not like the four strokes where the coolant is pumped into the jug first, then flows up through the head. Quote Link to comment Share on other sites More sharing options...
madjimmax Posted September 14, 2009 Report Share Posted September 14, 2009 If I'm not mistaken that's the purpose of a cool head it changes the direction of the water flow. Besides they also let you change dome size which can increase or decrease compression ratio. Maybe someone else will chime in also. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 14, 2009 Report Share Posted September 14, 2009 If I'm not mistaken that's the purpose of a cool head it changes the direction of the water flow. Besides they also let you change dome size which can increase or decrease compression ratio. Maybe someone else will chime in also. Yea the main purpose of a cool head is to change the compression ratio, and the ease of machining domes on a lathe vs machining / rechambering a stock head. Cool Heads dont really do much for cooling. Most of the coolant is just circulated and makes its way across the head. I dont see how it would bennifit a banshee to have the coolant flow from the front of the head to the back of the head. Quote Link to comment Share on other sites More sharing options...
cjcrete Posted September 14, 2009 Author Report Share Posted September 14, 2009 Yea the main purpose of a cool head is to change the compression ratio, and the ease of machining domes on a lathe vs machining / rechambering a stock head. Cool Heads dont really do much for cooling. Most of the coolant is just circulated and makes its way across the head. I dont see how it would bennifit a banshee to have the coolant flow from the front of the head to the back of the head. Here is a little more info, There is another hose routing on lf side into the rear or the cylinder. He must make another cooling port. Quote Link to comment Share on other sites More sharing options...
