Left cylinder not hitting
shelrad1
Try adjusting the air mixture screws on both carbs. Turn them in 1/4 of a turn each, give the motor 20-30 seconds to adjust, and see if it's any better. Just make sure that both air mixture screws are turned out the same number of turns. If the pilot jets are the right size, then you should have your air mixture screws turned out 1.5-2 turns. If they are out less than 1 turn, you need bigger pilot jets.
I fiddled with these as well. They were 1-1/2 turns out. It seems to run maybee a little better after I turned them in 1/4 more, but didnt solve the prob. When turned out more than 1-1/2 it runs worse.
