cool head
01trailshee
i actually run 20's, pro circuits, and +5.5 on 95 with stock porting and no deto. pulls hard as hell in the mid. yeilded less power with 100oct.
HUH....when I went from 110 fuel to 93, my friend with the DS650 was able to pull on me by almost 2 full bikes
I put in race gas, and we are dead even....have yet to race him with my new timing...my previous timing was -5...dont ask why...I just tore it apart and thats where it was...
odd....it must have to do with the timing. when i ran 100, then went down it was after i set it to +5.5, and pulled the mid a bit harder. of course, I'm using av gas, which is formulated to atomize differently
Edited by AKheathen
Someone forgot to ask you the most important question.
What elevation do you ride at?
If you're at a higher elevation, sometimes even a 19 or 20 is fine.
Second,
Cranking compression does NOT dictate the need for more octane, compression RATIO does.
NO fuel is rated for cranking compression. It is rated for compression ratio.
