thrown rod bearing
acroadam
to me $1500 to swap a crank is crazy, where are you? you can get a new crank for $350 r&i should run about $250...
now if you need a bore and pistons then your talking an extra $300-$350. say $50-$75 for gaskets?
so should be like $1100 ish?
i cant say anything without seeing the engine but if it's just a crank swap then buy a manual and some threebond and get it done.
if your in the portland oregon area i'll do it for $20 and a case of beer if you buy all the parts,gaskets and sealant...lol
Edited by swrbansheeboy
My buddy just bent a rod on his crank. He picked up a used stock crank for $100, seal kit for $45, gaksets for probably $30, sealant $7, honed cylinders himself (no bore needed) and I split the cases and swapped it, back together with cases and top end with pressure test for another $100! Granted, this was a "buddy deal" but damn! $1500?
Like said earlier, you could buy a complete motor for that. I would tackle it myself and take my time.
I hate paying other people to do shit, especially dealerships. They rob you blind and I can do better work then the ones ion my area, most have dumbasses working in their shops.
SP
alright.. now, where do you go about buying one? Ive been looking at ebay, they have some for sale at 280.00 and its a wiseco crankshaft.. but the same crank at wiseco is 500.00 so is it real or a scam? the seller has a real good sale history.....and it comes with everything for a complete bottom rebuild
Buy from a sponsor on here. HJR, FAST, M&M etc. They should be able to match if not beat any other price you find. Just call and check around. Don't forget your flywheel puller. Probably be able to pick up everything at one stop.
SP
to do it "by the book" your going to need a bunch of crap like a clymer manual and....
for tear down...
10mm socket
12mm socket
17mm socket
24mm socket
32mm socket
correct flywheel puller
http://www.motionpro.com/motorcycle/partno/08-0026/
impact driver
rubber mallet
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=39528
for re-assembly all the above minus the flywheel puller plus...
inch pound torque wrench
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2696
foot pound torque wrench
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=807
some three bond (i use 1104 but it got replaced by 1194)
http://www.magicracing.com/ThreeBond-1194-Liquid-Gasket-Sealer-35oz_p_84.html
some sort of clutch holding tool (i use a set of burnt clutches screwed to a set of steels with a penny jammed in the gears)
17mm wrench
i know i'm forgetting something but thats a pretty good list of all the stuff you will need to have besides seals and a crank...
