acroadam Posted September 5, 2009 Report Share Posted September 5, 2009 I have a thrown rod bearing.. I took it to a local atv shop and the guy told me he would install a new crankshaft for 1500.. that includes parts and labor.... Is that a resonable price?... and is this something i can do on my own? Quote Link to comment Share on other sites More sharing options...
Mjv420 Posted September 5, 2009 Report Share Posted September 5, 2009 Pretty expensive to me but everyone has their opinions. Depending on the damage done you might have to rebuild to top end also. Quote Link to comment Share on other sites More sharing options...
lt250rfd Posted September 5, 2009 Report Share Posted September 5, 2009 seems high priced, you could find a running motor for that price. Quote Link to comment Share on other sites More sharing options...
swrbansheeboy Posted September 6, 2009 Report Share Posted September 6, 2009 (edited) to me $1500 to swap a crank is crazy, where are you? you can get a new crank for $350 r&i should run about $250... now if you need a bore and pistons then your talking an extra $300-$350. say $50-$75 for gaskets? so should be like $1100 ish? i cant say anything without seeing the engine but if it's just a crank swap then buy a manual and some threebond and get it done. if your in the portland oregon area i'll do it for $20 and a case of beer if you buy all the parts,gaskets and sealant...lol Edited September 6, 2009 by swrbansheeboy Quote Link to comment Share on other sites More sharing options...
spurdy Posted September 6, 2009 Report Share Posted September 6, 2009 My buddy just bent a rod on his crank. He picked up a used stock crank for $100, seal kit for $45, gaksets for probably $30, sealant $7, honed cylinders himself (no bore needed) and I split the cases and swapped it, back together with cases and top end with pressure test for another $100! Granted, this was a "buddy deal" but damn! $1500? Like said earlier, you could buy a complete motor for that. I would tackle it myself and take my time. I hate paying other people to do shit, especially dealerships. They rob you blind and I can do better work then the ones ion my area, most have dumbasses working in their shops. SP Quote Link to comment Share on other sites More sharing options...
acroadam Posted September 7, 2009 Author Report Share Posted September 7, 2009 yeah i was thinking it could be something i do at home... is there anything special i need to put a crankshaft in? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted September 7, 2009 Report Share Posted September 7, 2009 A Clymers manual, Yamabond or three bond, gaskets, seals,tab lockwashers for clutch and sprocket (maybe), depending on runtime maybe rings. Sure ther's something else I forgot. Quote Link to comment Share on other sites More sharing options...
acroadam Posted September 7, 2009 Author Report Share Posted September 7, 2009 alright.. now, where do you go about buying one? Ive been looking at ebay, they have some for sale at 280.00 and its a wiseco crankshaft.. but the same crank at wiseco is 500.00 so is it real or a scam? the seller has a real good sale history.....and it comes with everything for a complete bottom rebuild Quote Link to comment Share on other sites More sharing options...
spurdy Posted September 9, 2009 Report Share Posted September 9, 2009 alright.. now, where do you go about buying one? Ive been looking at ebay, they have some for sale at 280.00 and its a wiseco crankshaft.. but the same crank at wiseco is 500.00 so is it real or a scam? the seller has a real good sale history.....and it comes with everything for a complete bottom rebuild Buy from a sponsor on here. HJR, FAST, M&M etc. They should be able to match if not beat any other price you find. Just call and check around. Don't forget your flywheel puller. Probably be able to pick up everything at one stop. SP Quote Link to comment Share on other sites More sharing options...
swrbansheeboy Posted September 11, 2009 Report Share Posted September 11, 2009 to do it "by the book" your going to need a bunch of crap like a clymer manual and.... for tear down... 10mm socket 12mm socket 17mm socket 24mm socket 32mm socket correct flywheel puller http://www.motionpro.com/motorcycle/partno/08-0026/ impact driver rubber mallet http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=39528 for re-assembly all the above minus the flywheel puller plus... inch pound torque wrench http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2696 foot pound torque wrench http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=807 some three bond (i use 1104 but it got replaced by 1194) http://www.magicracing.com/ThreeBond-1194-Liquid-Gasket-Sealer-35oz_p_84.html some sort of clutch holding tool (i use a set of burnt clutches screwed to a set of steels with a penny jammed in the gears) 17mm wrench i know i'm forgetting something but thats a pretty good list of all the stuff you will need to have besides seals and a crank... Quote Link to comment Share on other sites More sharing options...
