need help setting carbs on my banshee
bp12
if you still have the tors installed then you will adjust the throttle with the large aluminum screws on the back of the tors units.
if you have removed the tors then you should have some brass idle adjustment screws on the sides of the carbs that will raise and lower the carb slides that will adjust your idle speed.
if you dont have the tors and dont have the idle screws installed then you will either have to install the screws (recomended) or just hillbilly it up by adjusting out the brass set screws on the carb tops. by doing this you wont have any freeplay in the throttle and it's not recomended but it works...
