Alex29573 Posted September 3, 2009 Report Share Posted September 3, 2009 hey everyone i was wondering if anyone here knows the squish on these cool heads? do they run different squish numbers for different domes? Im looking into 21 or 22 cc domes... Also, when doing a compression test should i add 5 psi to what ever the gauge reads? I was told to do this because the compression tester doesnt thread into the combustion chamber as far in as the spark plug does.. So if my gauge reads 160 psi its really 165 psi when the spark plug is put on because of the volume it takes up (making the combustion chamber a couple of cc less. Quote Link to comment Share on other sites More sharing options...
Alex29573 Posted September 3, 2009 Author Report Share Posted September 3, 2009 anyone?? Quote Link to comment Share on other sites More sharing options...
spurdy Posted September 3, 2009 Report Share Posted September 3, 2009 (edited) anyone?? The squish clearance comes from the squish band which can be cut at different angles depending on the dome. Some builders have their own angles they like the squish band cut to. This shouldn't effect the volume of the dome very much. So your squish clearance would depend on the specs of the dome. I am sure that if you arder a dome from NOSS that Dave has a standard cut unless the person ordering specifies something different. As far as your compression check, I would just get the correct end for the tester. Otherwise your just guessing. SP Edited September 3, 2009 by spurdy Quote Link to comment Share on other sites More sharing options...
mopar1rules Posted September 4, 2009 Report Share Posted September 4, 2009 (edited) on the 19cc and 21cc pro-design domes that i seen my buddy use, gave squish clearances of .050", w/wiseco/cometic base gaskets. Edited September 4, 2009 by mopar1rules Quote Link to comment Share on other sites More sharing options...
Alex29573 Posted September 4, 2009 Author Report Share Posted September 4, 2009 on the 19cc and 21cc pro-design domes that i seen my buddy use, gave squish clearances of .050", w/wiseco/cometic base gaskets. kinda sucks... thanks for the info Quote Link to comment Share on other sites More sharing options...
dlnoss Posted September 8, 2009 Report Share Posted September 8, 2009 The 'standard' cut domes I make should have .035" to .040" clearance with the standard base gasket. -David Quote Link to comment Share on other sites More sharing options...
