ny98banshee350 Posted September 1, 2009 Report Share Posted September 1, 2009 ok so quick background on my 4 mill i was told by my quad shop that id b ok 2 run 93 octane in it well i tryed but it bogged like a mutha so i went to cam 2, 100 octane, it was running much better but after a lil bit the plugs kept comming loose so i went to the shop yesterday and asked my buddy bout this.. he called vito's and asked, they told him that the motor keeps detonating, that i need 2 run a higher octane which is no problem my compression is real high so i think like 180-195 range, but my ?? is do they make plug locks? i looked online but came up with nuthin Quote Link to comment Share on other sites More sharing options...
slamed91si Posted September 1, 2009 Report Share Posted September 1, 2009 check out ebay item#110429847902 it goes off in 5 days Quote Link to comment Share on other sites More sharing options...
ny98banshee350 Posted September 1, 2009 Author Report Share Posted September 1, 2009 check out ebay item#110429847902 it goes off in 5 days that works thanks! Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 1, 2009 Report Share Posted September 1, 2009 (edited) If you have to run plug locks, you have a serious problem and the plug locks are junk just a FYI. Bump up your fuel or drop your comp if the plugs are backing out. That a sign thats somethings not right. Its a band aid running the plug locks ..and it will eff up anyways if your not running the right fuel for your comp. You need to run VP110 with the high of compression man. Or something equivalent to VP110. Edited September 1, 2009 by savage420 Quote Link to comment Share on other sites More sharing options...
XxMeltIcexX Posted September 1, 2009 Report Share Posted September 1, 2009 As chris said, stay clear of plug locks. If its detonating you have underlying problems that wont be fixed by a lock. Quote Link to comment Share on other sites More sharing options...
theshee Posted September 1, 2009 Report Share Posted September 1, 2009 no plug locks, just figure out your compression and then use the correct fuel for your altitude. My plugs were doing that on my 421 and it was because I wasnt running high enough octane fuel for my compression. 50/50 race gas mix fixed my problem. Quote Link to comment Share on other sites More sharing options...
ny98banshee350 Posted September 1, 2009 Author Report Share Posted September 1, 2009 thats what vito's said so i will be running the 110 race gas and i wont be running the locks! thanks guys Quote Link to comment Share on other sites More sharing options...
crash&burn Posted September 26, 2009 Report Share Posted September 26, 2009 ok i have the same problem i run 110 octane with around 190 comp. and it still backed out..... i was told by running the coolhead that i have they like to back out any ways... so is my head the problem or what do i need to do next to fix this problem.... Quote Link to comment Share on other sites More sharing options...
VegasJeff Posted September 26, 2009 Report Share Posted September 26, 2009 i was told by running the coolhead that i have they like to back out any ways What brand head are you using? Although, as far as I know, it should not matter. If the plugs are backing out, there is a problem somewhere, not the brand of head. Quote Link to comment Share on other sites More sharing options...
crash&burn Posted September 26, 2009 Report Share Posted September 26, 2009 What brand head are you using? Although, as far as I know, it should not matter. If the plugs are backing out, there is a problem somewhere, not the brand of head. Its a COOLHEAD with 16cc Domes just want the problem fixed Quote Link to comment Share on other sites More sharing options...
VegasJeff Posted September 26, 2009 Report Share Posted September 26, 2009 Oh ok, Pro Design. What is the squish clearance and what is the timing set at? Quote Link to comment Share on other sites More sharing options...
crash&burn Posted September 26, 2009 Report Share Posted September 26, 2009 Oh ok, Pro Design. What is the squish clearance and what is the timing set at? I Dont Know what squish clearence is but timing is about a +5 Quote Link to comment Share on other sites More sharing options...
rubberneck Posted September 27, 2009 Report Share Posted September 27, 2009 what elevation are you at? 16 cc domes are tiny. I just checked the compression on my 350 with 19cc domes, and it is kicking 180 psi at sea level. You might need bigger domes. I would think 16 cc domes would only be ok at high elevation or maybe methanol. Quote Link to comment Share on other sites More sharing options...
crash&burn Posted September 27, 2009 Report Share Posted September 27, 2009 my elavation is at sea leval live on the coast.... would going to a like 18cc or 20cc dome cause a huge loss in power to fix the problem... running menthanol or alcohol isnt really option where live its kinda hard to get ahold of trien to avoid that..... Quote Link to comment Share on other sites More sharing options...
bode1 Posted September 27, 2009 Report Share Posted September 27, 2009 ok i have the same problem i run 110 octane with around 190 comp. and it still backed out..... i was told by running the coolhead that i have they like to back out any ways... so is my head the problem or what do i need to do next to fix this problem.... I'm at 160lbs at sea level with 20cc domes, I'm running av gas now, and it seems to be working out well. I think Rubberneck is right, you need bigger domes. Quote Link to comment Share on other sites More sharing options...
