no spark on left cylender HELP
ok here goes was riding yesterday all day like 5 hrs no problems then hit a big mudd hole and now my bike is only running on one cylender. i had my buddy pull me to try to pop start the bike and the left cylender back fires and the right one is fine i have tested the wires from the coil to the clear plug in the rear and thats all good also tested the coil for cont. and i think thats good. also took the carb and reeds off to look for water and there was none not sure what else to try??? i tryed to get the wires out of the coil and broke the keeper tabs off and still cant get the wires out whats next????????
i have took the carbs off and there fine no water in them. also changed plugs had to pop start and still the same right cylender runs and the left back fires. i dont think the coil can be bad cause it runs on 1 cylender, can it still be bad ?? im thinking its the wire or the boot can you remove the wires?? i dont want to keep pulling on them if they dont come out.
ok just replaced the boots with the ones you said, still no spark, looking at the bike from the right side the orange wire goes to the front and the black to the back? whats next the wires? also sanded down the gorund for the coil where it bolts to the frame
Edited by slamed91si
Switch the wires and plugs from side to side and see if your problem switches sides if does the plug, wire, or cap is bad, if it doesnt you got other problems. Do a compression check on both sides.
Im with bansheestang , Check the compression on the suspect side
Just went through this myself, sounds like you have done in a piston
i dont understand how no spark can mean i have a bad piston but ill check it anyway thank you all for the help
I was wondering the same thing. I am having the same problem but my left side is still sparking, just a weak spark. My right side runs and idles fine, but the left only fires sporadically and when I rev it it runs better.
