POORBOY350 Posted August 28, 2009 Report Share Posted August 28, 2009 going to build one just wantin to see some of what yal run. get some ideas. i got a 4mil cub janssen +2 swingarm. stock frame, elka rear shock, i shocks front w/ +a arms... just wantin to get some ideas see how yal designed and built yals... thanks. Quote Link to comment Share on other sites More sharing options...
terr1bleone Posted August 29, 2009 Report Share Posted August 29, 2009 going to build one just wantin to see some of what yal run. get some ideas. i got a 4mil cub janssen +2 swingarm. stock frame, elka rear shock, i shocks front w/ +a arms... just wantin to get some ideas see how yal designed and built yals... thanks. pics of mine in this thread, its more of a saftey catch bar though incase i cant controll it. I havent had a problem with it preloading but have been told it should be the same length as your wheelbase for saftey. http://bansheehq.com/forums/index.php?showtopic=120436&pid=1046945&st=0entry1046945 Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 29, 2009 Report Share Posted August 29, 2009 Normally.... You make a 3 point bracket for your wheelie bar. Two points mount at the bottom pinch bolts (taking into consideration you bought a roundhouse carrier style arm) and the third is above the pinch bolts. A triangle of sort...if you will. Most of us use a go kart type tire for it. Here's the bracket I'm talking about at the back of the bike. It bolts to the pinch bolts on the carrier and the lower shock bolt. Quote Link to comment Share on other sites More sharing options...
POORBOY350 Posted August 29, 2009 Author Report Share Posted August 29, 2009 thanks man that helps alot. only thing now is should i strut it? or how would it act if i did a design like you have and left my shock...? its an elka dual rate or whatever its nice really hate to take it off to put in a piece of steel lol. yes i have a plus 1 or 2 janssen swinger not sure which one it is. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 29, 2009 Report Share Posted August 29, 2009 I won't run a wheelie bar without a strut. When you run a shock, it hits the bar, squats the back end and takes away holeshot inertia. Quote Link to comment Share on other sites More sharing options...
