Compression ?
When I first got the bike last year, I did a compression test and got 110/115 psi.
After two months I replaced just the rings and the compression went up to 120/125 psi.
I just got my cylinders back from Jeff with a fresh hone and bore, new pistons, top end gaskets and new seals.
I got done earlier putting the motor back togheter and when I did a compression test I got 160/165 psi.
My question is, what could be causing the 5 psi difference?
I did a leakdown test and it hold 6 psi for 6 minutes.
Also since my compression is around 165 I went and got a five gallon can of power mist
t105 racing fuel which claims to be 109 octane. Should I run a 50/50 mix?
Mods are:
+4 timing
20cc domes
FMF Gnarly
pro flow with K&N and lid on
VF3s
stock carbs, 290 main, 27.5 pilots,
needle on stock position
airscrew 1 1/2 turns out
sea level
80 degrees temperature
Thanks for any advice guys.
you should be able to get away with pump but it wouldnt hurt to run a 50/50 mix. as long as the comp is within 10 i wouldnt worry about it.
Stock porting and stock head? Could be inconsistencies in the stock casting. Exhaust roof height and dome size also play a part in your compression besides how well your rings seal.
SP
Stock porting, and the first two times I did a compression test I had
the stock head, now for the fresh top end I put a pro design cool head with 20cc domes.
It's just weird that with a fresh bore and new pistons and it still
has a 5 psi difference between cylinders.
I've never used or mixed race gas before, so if I go with a 50/50
mix that means if I put 2 gallons of pump gas I have to put 2 gallons of race gas right?
Thanks guys, I'm still learning as you can see.
I guess I shouldn't worry about it then.
You guys think I should run a 50/50 mix or a 25/75 mix?
Anybody have any experience with Power Mist T105 Racing Fuel?
They also make a premix oil that claims to be the ultimate 2stroke oil.
Never heard of it and I'd bet you'd be ok with high octane pump gas. I run Sunoco Turbo Blue.
SP
  • 3 weeks later...
with a leakdown test it should hold longer than 6 min i think it should hold like over night i think
[/quot
Yeah, I left the air in for like ten minutes and then released it to keep putting the motor back together.
I'll prolly be doing another one in like a week to make sure nothing is leaking.
