2SLO Posted August 15, 2009 Report Share Posted August 15, 2009 I dont have the slightest clue where to start! haha. i bought this banshee in a box, did a top end rebuild, put it all together, and i can only get it to start by spraying brake cleaner in the carbs, and if i dont keep in the throttle to keep it running, it just dies. stupid carbs! theyre clean as can be.. im just used to a laptop! Quote Link to comment Share on other sites More sharing options...
350scabarat Posted August 15, 2009 Report Share Posted August 15, 2009 Look under the tank towards the radiator. . .on the left there's a little black unit. Unplug it. Thats the throtle overide system. It always gives shit. . Its just there to kill the motor if ur throttle sticks. . . Let us know if that workd Quote Link to comment Share on other sites More sharing options...
2SLO Posted August 15, 2009 Author Report Share Posted August 15, 2009 I tried disconnecting the tors, and still no dice. I got advice from a friend about screwing the "air" screws all the way in and then back out about two turns... tried it with no luck.. Quote Link to comment Share on other sites More sharing options...
350scabarat Posted August 15, 2009 Report Share Posted August 15, 2009 Make sure the float bowls arnt swopd? If u take them off ul c the 1 has a jet in that the other 1 dsnt. . .the one with the jet goes on the left carb with the choke. Then make sure ur slides are in the rite way. . .the cutouts go towards the air filter. Check that ur reeds arnt broken? Do u hav consistant spark? Take both plugs out then put 1 plug in its cap and earth the plug on a head bolt. . Kick the kickstart and check 4 spark. . It should be a purple blue colour. Make sure u geting petrol? Open the screws at the botom of the floats to check if petrol runs out. . .let us know? Quote Link to comment Share on other sites More sharing options...
captainhowdie Posted August 15, 2009 Report Share Posted August 15, 2009 You said the carbs are clean, But double check the pilot jets. If there plugged it will not idle!! Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted August 15, 2009 Report Share Posted August 15, 2009 You have to remove the main, and pilot jets to clean them properly. Also, make sure to squirt carb cleaner through all the passages in the carbs to make sure they are clean. Quote Link to comment Share on other sites More sharing options...
2SLO Posted September 1, 2009 Author Report Share Posted September 1, 2009 ive been been working on performance cars and boats for 8 years as my profession, and i cant get a frickin banshee to run?!?!?! anyone live in the st. louis area want to help me out?! Quote Link to comment Share on other sites More sharing options...
Michael66 Posted September 1, 2009 Report Share Posted September 1, 2009 Are the carbs synced? Might only be on one cylinder. Quote Link to comment Share on other sites More sharing options...
Idontknowwhy Posted September 1, 2009 Report Share Posted September 1, 2009 Choke tube in place? Little black hose that runs between both carbs check it.. Quote Link to comment Share on other sites More sharing options...
2SLO Posted September 1, 2009 Author Report Share Posted September 1, 2009 Choke tube in place? Little black hose that runs between both carbs check it.. choke tube is NOT there. ill grab some vacuum hose from work today and get one on there. ill report back tonight! Quote Link to comment Share on other sites More sharing options...
2SLO Posted September 2, 2009 Author Report Share Posted September 2, 2009 alright. i put the choke tube on there, no luck. still needs brake clean to start, then while its running, if i spray shots of brake cleaner into the left carb, it stays at its normal idle and kees running, but if i spray it in the RIGHT carb, it idles up like crazy! the left pipe gets way hotter way faster than the right pipe. any ideas? Quote Link to comment Share on other sites More sharing options...
Michael66 Posted September 2, 2009 Report Share Posted September 2, 2009 Sounds like the right carb slide is open allowing thw brake clean in the motor Quote Link to comment Share on other sites More sharing options...
2SLO Posted September 4, 2009 Author Report Share Posted September 4, 2009 alright, i cleaned the shit out of the carbs and put 27.5's and 290's in because of the procircuit pipes. now, the RIGHT side pipe gets warm, pings, and smokes its ass off (super rich i think) and the LEFT side never gets warm at ALL and dosent smoke untill you rev the pissout of it! GRRR this is starting to get old.. tomorrow ill put the stock pilots in, and see what it does. any idea on the one side smoking and one side not??? Quote Link to comment Share on other sites More sharing options...
Michael66 Posted September 4, 2009 Report Share Posted September 4, 2009 alright, i cleaned the shit out of the carbs and put 27.5's and 290's in because of the procircuit pipes. now, the RIGHT side pipe gets warm, pings, and smokes its ass off (super rich i think) and the LEFT side never gets warm at ALL and dosent smoke untill you rev the pissout of it! GRRR this is starting to get old.. tomorrow ill put the stock pilots in, and see what it does. any idea on the one side smoking and one side not??? I had te same problem. Put two new to me used carbs from e bay now mine purrs like a kitten at idle. Look at your throttle cable and make sure it is in it's keepers at the y. I put some quiksteel on mine to hold them in there. Think that was 1/2 my problem pulling the carbs out of sync. I am new to banshees too and my first one was also a rebuild. The one thing i learned is the carbs have to be the exact F*in same or it wont run worth a shit. Quote Link to comment Share on other sites More sharing options...
2SLO Posted September 4, 2009 Author Report Share Posted September 4, 2009 i hope i dont have to buy new carbs! Quote Link to comment Share on other sites More sharing options...
