Nitrous installed
kubitza123
Got it all finished and put together last night. Going to run it threw some heat cycles tonight then tune it tomorrow morning and if all goes well race sat. night. Nitrous systemed turned out good i thought built the wiring harness and heat shrink all connections,wire loomed etc. The front stainless tank that mounts in front of the pipes is the race gas enrichment fuel for the nitrous. Don't have a pick but theres also a stainless battery box we built that mounts on the top bolt of the strut between the filters. Has the micro switch built into the billet throttle and added a billet push button so i can control and use the nitrous whenever i choose.
Might help give any1 wanting to install a kit some mounting ideas etc
Overall i think it came out well and nice and neat.
Thanks Guys running it this weekend if all goes well tuning it tomorrow. With a 20- 30 shot on it should be around 150hp at the rear wheels 120-130 on motor alone its on alky.
Hoping to see 5.8's or better on motor alone in the 1/8th and around 5.5's-5.7's with the gas on if i can do my part. I weigh 200lbs so not a light jockey either and 6'3.
  • 1 month later...
ive seen alot of people running race gas or pump gas for their fuel to spray with the nitrous.. theyve also had alot of tuning problems cause of the two fuels mixing and not burning at the same rates.
im spraying mine with the same fuel im running, alcohol.. its shown more on the dyno, you dont have to carry an extra fuel tank, nitrous kits can be made put together from nos or nx with alcohol fuel solenoids so you dont have a problem with the plungers on them.
