valdez_banshee Posted August 10, 2009 Report Share Posted August 10, 2009 whats up guys im new to website and owning a banshee. i have following mods and would like to know what u guys recomend to do next for power.... also i try do a little drag but wen i launch in second it jst boggs at line...please help thanks prodesign billet plate w/k&n filter toomey t3 exhaust w/290 main/25pilot and at sea level Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted August 10, 2009 Report Share Posted August 10, 2009 You could bump your timing with a timing plate and raise your compression with a cool head. You will most likely end up doing both of those anyway if you plan on building your bike up more! If you really want to get some power of it, do the timing and compression along with a port job and pipes to suit your riding needs! Call Jeff at FAST racing and he can help you determine what to do next. 1-785-364-5325 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 10, 2009 Report Share Posted August 10, 2009 first off, id bump up that pilot to a 27.5. it might help with your bog off the line. most setups with aftermarket pipes require a 27.5 anyway, especially at sea level. sounds like some porting is in store for you, along with bigger carbs. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted August 10, 2009 Report Share Posted August 10, 2009 whats up guys im new to website and owning a banshee. i have following mods and would like to know what u guys recomend to do next for power.... also i try do a little drag but wen i launch in second it jst boggs at line...please help thanks prodesign billet plate w/k&n filter toomey t3 exhaust w/290 main/25pilot and at sea level As said you may need 27.5 pilot jets, timing plate (set at +4) would be my next suggestion followed by a F.A.S.T. head for more compression! Then if money remains go for some V force reeds, and then porting later when money allows. If your a heavier rider you may consider dropping to a 13t on the front sprocket. Quote Link to comment Share on other sites More sharing options...
valdez_banshee Posted August 14, 2009 Author Report Share Posted August 14, 2009 :biggrin: thanks guys will do fill u guya in this weekend bout bogging.... As said you may need 27.5 pilot jets, timing plate (set at +4) would be my next suggestion followed by a F.A.S.T. head for more compression! Then if money remains go for some V force reeds, and then porting later when money allows. If your a heavier rider you may consider dropping to a 13t on the front sprocket. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 14, 2009 Report Share Posted August 14, 2009 valdez, AK? what's your name? might know you. hit me up, i can prob. help you out. Quote Link to comment Share on other sites More sharing options...
