klemet banshee Posted August 6, 2009 Report Share Posted August 6, 2009 (edited) i got most of the jetting zeroed in. its still sluggish off the bottom end and jus looking if i should go lower. there was a 65 pilot and i dropped to a 58 and it made a shit load diffrence should i go lower or jus play with the needle? its on the middle clip also its 2 into 1 with fmf pipes kn pod with outerwear agrresive trail port shaved head stock stroke note*** i dont have the lectron on now its a 36 pwk Edited August 6, 2009 by klemet banshee Quote Link to comment Share on other sites More sharing options...
Sammy Posted August 6, 2009 Report Share Posted August 6, 2009 Lean your clip out one notch and see how it runs. Since you have a trail port there should be no sluggishness down low. It should pretty much be instantaneous power delivery. Also I would highly recommend against the Dynoport 2>1 pipe. It has been proven to not perform that well. I would go with some Pro Circuits platinum's or PT mids. I didn't see in your sig what type of reed your running either. Hopefully it's a good low tension reed. Like a Boyesen or carbon tech. Quote Link to comment Share on other sites More sharing options...
trex banshee Posted August 11, 2009 Report Share Posted August 11, 2009 David, What do you have the timing set on? Its going to want some advance, +4 would be great. Also, if you can get a hold of some i strongly recommend 28pwks. Great carb for that porting. Quote Link to comment Share on other sites More sharing options...
