slopoke Posted August 6, 2009 Report Share Posted August 6, 2009 As some of you know I have had a bad xperience with a boss billet intake (2 piece) leaking air. What type intake do yall run. I need something fo 35mm carbs and the added space to clear the clutch actuator. I have vf3 also. Did I just get a bad one or are they al like that for the most part? Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted August 6, 2009 Report Share Posted August 6, 2009 I run Pro-designs billet intakes with VF3's under them, never looked back...... :thumbsup: Quote Link to comment Share on other sites More sharing options...
shanYE west Posted August 6, 2009 Report Share Posted August 6, 2009 I've used white knukle and Boss intakes with no problem.. We got a set of chariot intakes on a 10mil cub and thats pretty good too. Quote Link to comment Share on other sites More sharing options...
toolucky Posted August 6, 2009 Report Share Posted August 6, 2009 I have Cheetah Cylinders so there is an extra bolt in the top and the bottem of each intake but i use UPP's and they seem to work great and they keep my 35's high enough to miss the actuator arm. Quote Link to comment Share on other sites More sharing options...
slopoke Posted August 6, 2009 Author Report Share Posted August 6, 2009 420, do those still use the boost bottle? I hate to give up that 15 extra horsepower(lol) but I was thinking of trying to get away from it. Do u have a photo of them or are they the ones with the big ole boost bottle? Do I even need a crossover? Quote Link to comment Share on other sites More sharing options...
3SGTE Posted August 6, 2009 Report Share Posted August 6, 2009 I use trinity 3/4" reed spacer for clear my clutch actuator with my pwk35 have 34-35mm UPP intake with boost bottle have vf3 and stock cylinder Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted August 6, 2009 Report Share Posted August 6, 2009 420, do those still use the boost bottle? I hate to give up that 15 extra horsepower(lol) but I was thinking of trying to get away from it. Do u have a photo of them or are they the ones with the big ole boost bottle? Do I even need a crossover? Nope, i did away with the gayness of the boost bottle. :thumbsup: Made my own x-over for it so i didn't have to run that POS on there. Yes i probably could have just blocked them off but i just made my own as it only cost a few bux for the fuel line 2 worm clamps and the uni-coil. Im pretty sure it's 5/8 automotive fuel line then i stuck a metal uni-coil over the tube so the bend didnt kink. IMO it looks better, takes up way less room and don't leak like the PD boost bottle did with there gay rubber grommets. Here is a pic of mine what i did. Works flawlessly now. :beer: The uni-coils can be bent all the way to 180 degrees with no kink. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 6, 2009 Report Share Posted August 6, 2009 i run the UPP intakes on my 10mm cub motor. Quote Link to comment Share on other sites More sharing options...
slopoke Posted August 6, 2009 Author Report Share Posted August 6, 2009 Nope, i did away with the gayness of the boost bottle. :thumbsup: Made my own x-over for it so i didn't have to run that POS on there. Yes i probably could have just blocked them off but i just made my own as it only cost a few bux for the fuel line 2 worm clamps and the uni-coil. Im pretty sure it's 5/8 automotive fuel line then i stuck a metal uni-coil over the tube so the bend didnt kink. IMO it looks better, takes up way less room and don't leak like the PD boost bottle did with there gay rubber grommets. Here is a pic of mine what i did. Works flawlessly now. :beer: The uni-coils can be bent all the way to 180 degrees with no kink. That looks good. I will try that. I don't likethe boost bottle too big and useless, Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted August 6, 2009 Report Share Posted August 6, 2009 As some of you know I have had a bad xperience with a boss billet intake (2 piece) leaking air. What type intake do yall run. I need something fo 35mm carbs and the added space to clear the clutch actuator. I have vf3 also. Did I just get a bad one or are they al like that for the most part? BOSS fucking sucks period Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 6, 2009 Report Share Posted August 6, 2009 F.A.S.T. manifold is sweet. just rebuilt my bike and could actually notice a difference with the bottom end plus it hits hard up top! Quote Link to comment Share on other sites More sharing options...
2strokespirit Posted August 6, 2009 Report Share Posted August 6, 2009 I used Boss on my 4mm. Now I run upp with reed spacers.. Upp is tough as can get. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 6, 2009 Report Share Posted August 6, 2009 i run the UPP intakes on my 10mm cub motor. Dittto. If I ever decide to put NOS on my bike, I'll give Chariot intakes a try....everything I've gotten from them has been top notch. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted August 6, 2009 Report Share Posted August 6, 2009 Yeah these work well plus seem to have a bit more torque than most.... http://www.farmandsandtoys.com/partdetail.asp?partid=190 UPP works well to as they wont hit the clutch arm at least on 4mm cubs on up.. Still do on stock cyls though without spacers. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 6, 2009 Report Share Posted August 6, 2009 F.A.S.T. manifold is sweet. just rebuilt my bike and could actually notice a difference with the bottom end plus it hits hard up top! Not to be a smart ass...but do you think the extra bottom end is from having a motor rebuilt...not just intakes? :wink: Quote Link to comment Share on other sites More sharing options...
