yamahaman244 Posted August 4, 2009 Report Share Posted August 4, 2009 hey guys i am wondering for a banshee like mine is on the stock bore 64 m and if i have to rebuild do i have to get a bigger conecting rod or can i use the same one Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted August 4, 2009 Author Report Share Posted August 4, 2009 hey guys i am wondering for a banshee like mine is on the stock bore 64 m and if i have to rebuild do i have to get a bigger conecting rod or can i use the same one ???????????? Quote Link to comment Share on other sites More sharing options...
spurdy Posted August 4, 2009 Report Share Posted August 4, 2009 ???????????? I am confused as to why you would think you might need different connecting rods? SP Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted August 4, 2009 Author Report Share Posted August 4, 2009 I am confused as to why you would think you might need different connecting rods? SP well i was just wondering like for the bigger piston or somting so i dont then Quote Link to comment Share on other sites More sharing options...
slopoke Posted August 4, 2009 Report Share Posted August 4, 2009 have you blown it up? Quote Link to comment Share on other sites More sharing options...
firebanshee Posted August 4, 2009 Report Share Posted August 4, 2009 well i was just wondering like for the bigger piston or somting so i dont then No, your stock ones will work fine as long as they are not bent or something else is wrong with them :cool: Quote Link to comment Share on other sites More sharing options...
spurdy Posted August 4, 2009 Report Share Posted August 4, 2009 No, your stock ones will work fine as long as they are not bent or something else is wrong with them :cool: x2 Adding a long rod crank (5mm longer then stock) reduces the angle of the rod against the wrist pin position and reduces stress against the skirt of the piston. Standard length rods can be used regardless of piston size. SP Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted August 4, 2009 Author Report Share Posted August 4, 2009 x2 Adding a long rod crank (5mm longer then stock) reduces the angle of the rod against the wrist pin position and reduces stress against the skirt of the piston. Standard length rods can be used regardless of piston size. SP allright thanks guys i was jw if u had to get a special one but if the stock one will work then i will use that one becaue mine shee is pretty stock Quote Link to comment Share on other sites More sharing options...
