ThE_BaNsHeE_mAn88 Posted August 3, 2009 Report Share Posted August 3, 2009 ok i just rebult my bike a few days ago and i was riding it the other day and at the top of 5th and 6th gear it was makeing a weird crackaling noise and now it wont fire on the left side, but befor it stoped working it was like spiting and spotering likeit was flooded, i dont think i blew it up its just running fucked up. oh and then i put new plugs in it and it started up and ran on both sides for about a couple of minutes then i hit the gas and it bogged down and the left side styoped fireing. i have no idea whats going on with it i need some help guys. thanks Derick Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 4, 2009 Report Share Posted August 4, 2009 swap the plug wires and see if it changes sides. then, clean your carbs out real good, one at a time. check your reeds while your in there. sounds like a broken reed, plugged jet or plug cap. Quote Link to comment Share on other sites More sharing options...
TwistedSheeRida Posted August 4, 2009 Report Share Posted August 4, 2009 knock on your bowl your floats could be getting stuck Quote Link to comment Share on other sites More sharing options...
ThE_BaNsHeE_mAn88 Posted August 6, 2009 Author Report Share Posted August 6, 2009 thanks guys i figured it out i used a shit ton of assembly lube when i put the jugs back on and it just fucked with the plgs the both stoped working so i oput new ones in and it runs awsome now no problems. Derick Quote Link to comment Share on other sites More sharing options...
