POWER JETS ?
Do you have any drill bits small enough to fit in the power jet? You can then measure w/a mic. I don't know what range of jet sizes a powerjet can make up for, but it is a pretty good amount. You should be able to get pretty close measuring the PJ. Obviously you will not flow anymore than the barb for the PJ that the fuel line connects to so you might want to measure that as well to make sure it isn't smaller than the tube. It shouldn't be though....
you can use a power jet with gas.. but.. usually the main jet is suffiecent in supplying enough fuel that a power jet isn't required. But.. the dump tubes have been drilled bigger in alky carbs.. So unless its a mikuni carb.. your dump tubes is set at what ever they were drilled at.
