jmiller Posted July 30, 2009 Report Share Posted July 30, 2009 Hey everyone i gotta banshee with a dune port done by Jeff at F.A.S.T, nology coil and hotwires, cool heads 20cc domes (135psi), wiesco pistons (10 over), 330 mains 27.5 pilots stock clip, advanced timing +5 running pump 93 octane, shearer inframe pipes, k&n pods, what next??? i was thinkin carbs or maybe v-force 3 :shrug: ... currently stock carbs reeds cylinders crank ect. i eventually am planning on a 421 cub 4mill But for now what would you recommend and would that work with a cub in the future...?? Top end junkie Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 30, 2009 Report Share Posted July 30, 2009 Hey everyone i gotta banshee with a dune port done by Jeff at F.A.S.T, nology coil and hotwires, cool heads 20cc domes (135psi), wiesco pistons (10 over), 330 mains 27.5 pilots stock clip, advanced timing +5 running pump 93 octane, shearer inframe pipes, k&n pods, what next??? i was thinkin carbs or maybe v-force 3 :shrug: ... currently stock carbs reeds cylinders crank ect. i eventually am planning on a 421 cub 4mill But for now what would you recommend and would that work with a cub in the future...?? Top end junkie My guess would be that with your supporting mods you are on target with some reeds and carbs. If your going with a cub in the future, it would be my opinion to go with some V Force reeds. It seems they are one of the best to run with the cubs (but I am not a big cub guy so if someone else says something different, go with them!). SP Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 30, 2009 Report Share Posted July 30, 2009 reeds and carbs for sure.. youre choking that motor right now. call jeff and see what he recommends. Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted July 30, 2009 Report Share Posted July 30, 2009 I have similar mods. How much difference would bigger carbs actually make on a stock stroke/bore motor? Quote Link to comment Share on other sites More sharing options...
00tbanshee Posted August 1, 2009 Report Share Posted August 1, 2009 not sure what type of riding you do but if its not straight out dragging then i would get a set of 35pwks for the motor you got and it will also work on the cub as well Quote Link to comment Share on other sites More sharing options...
