how many horses did your machine crank out ?
just a question. how many horses have you squeezed out of stock jugs, stock carbs, and stock stroke crank. what was your list of mods? i love it when people do alot with very little in any situation in life. i have alot of respect for that. but this time id like to know what kind of power members here have achieved with stock looking cylinders, carburetors, and crank.
Only obstruction is the 35mm Pwks i had on it, I put down 59.8 horses and 42.0 ft/lbs of torque. Other mods were vf1s, prodesign cool head with 17cc domes, k&n pods, +4 timing, Toomey T5s, and a trail/dune port. :biggrin:
66.78hp at 8,750 rpm on a Dynomite Crank Dyno.
-Dynoport ported stock cylinders 188 degree exhaust duration
-Pro Design Coolhead with 18cc domes (185psi comp)
-Dyna Ignition with custom programmed curve
-Stock reed cages with carbon tech mid tension reeds
-Dual 28mm Mikuni TM flatslide carbs with K&N Pods
-Shaved flywheel
-Cascade Clutch kit with the roller bearing ball end adjuster
-Dyna coil with NGK Plug Caps
-Stock Crank
-Wiseco Pistons (stock bore), squish setup at .043"
-Pro Circuit pipes with the standard silencers (ceramic coated)
-BR8ES spark Plugs
-110 octane sunoco with castor 927 at 40:1
-Stock intakes and stock boost bottle
-Shaved flywheel
-Stock Crank
-BR8ES spark Plugs
impressive :notworthy: what kinda port work?
-Shaved flywheel
-Stock Crank
-BR8ES spark Plugs
For anyone who cares, the Dynomite dyno is made by Land & Sea. They are good dynos and should be labeled with this: dynomite.jpg
Land & Sea didn't take that idea from one of my engineers at a previous employer. :biggrin:
The best I did was the following when I was still in skool.
*OEM welded crank balanced with entire rotation assembly.
*OEM remachined head.
*OEM carbs bored out to 30mm and bored for larger slides (not worth the time and effort).
*OEM cylinders with sleeves pressed out, casting and sleeves ported, then reassembled (done on a live 4 axis CNC mill). You could consider it a hot dune port by industry standards.
*OEM pistons machined to be equal weight.
*OEM rods machined to be equal weight.
*OOF handmade pipes.
*OEM reed cages, ported, with CF reeds (I made the reeds, which wasn't worth the effort).
*M100 fuel w Castor 927 oil.
*Dyna ignition w/ OEM coil.
*The radiator and cooling system in the test cell was used with an electric water pump and thermostat set at 190 degrees.
The engine ran for ~10 hours on a Super Flow water brake engine dyno (driven off of the crank). It failed a reused OEM crank bearing at about that time. Peak mean horsepower was 101hp and I can't remember the torque, but I can try and find my engine build book for the engine if anyone cares.
that is funkin crazy..
51.55 hp and 31.3 torque with mods in my sig 60 mm stock bore and no real intake port work just casting flaws removed and the transfers smoothed I did take some material out of the exhaust side and polish it. I have played around with a few set of cylinders and a couple of books and cds on 2 stroke port work. no I am not a pro but it is good to know you did it yourself
62.6 hp on the dyno @ Little Sahara Sand Dunes Oklahoma.
Mods on my 03 shee:
Toomy T5's
HJR agressive dune port
Weisco Pro-lite pistons
noss cool head 20cc domes
+6 timing
welded stock crank
stock stroke
stock carbs 330mains, stock needle 3rd clip, 27.5 pilots, air screws 1 turn out
k/n pods
lightened flywheel
Vforce 3 reeds
50/50mix C12 108octane and 93octane super unleaded
66.70 hp and 42 lbs of torque on a dynomite dyno (and a burnt clutch)
stock carbs
stock stroke
stock cylinders with an HJR dune port
+5 timing
21cc domes (pump gas)
k&n pods
vf3's
wiseco pro-lites on first bore
everything else was stock
link to dyno sheets in my sig
stock carbs
stock stroke
+5 timing
k&n pods
vf3's
Was it a rear wheel or crank dyno?
