stroking Posted July 25, 2009 Report Share Posted July 25, 2009 HAS anyone ever done a test to see if a drag axle really lowers your E.T Times ? had one guy tell me he went from 7.20's to 6.90's when he which but i find that hard to believe! anyone ? Quote Link to comment Share on other sites More sharing options...
docjcwatson Posted July 25, 2009 Report Share Posted July 25, 2009 I'll believe it. A drag axle is a considerable amount of less weight. The least amount of centrifugal mass that you can have, the faster you will go. Now I don't know if he really did lose that much time off his E.T., but I know you will lose some. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 4, 2009 Report Share Posted August 4, 2009 I guess anything is possible, I know you won't see 3 tenths in 300 foot, but pavement....never know. It is a lot less rotating mass. With any drag axle, you're also getting more adjustability for rear width. You want the rear tires sucked under neath you for traction. The trade off is stability.... Quote Link to comment Share on other sites More sharing options...
popa_top2000 Posted August 4, 2009 Report Share Posted August 4, 2009 I dont know for sure but I guess its possible. I talked myself into getting a drag axle and I'm glad I did. That thing is super light compared to the stock axle. Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted August 4, 2009 Report Share Posted August 4, 2009 That is definitely the next thing on my list to get. Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted August 5, 2009 Report Share Posted August 5, 2009 I got a JJ&A gun drilled drag axle and it did help trim a little from my et's in 500ft dirt.As mentioned they are considerably lighter and allow for more adjustment of the rearend width. Steve Quote Link to comment Share on other sites More sharing options...
quadgod211 Posted August 5, 2009 Report Share Posted August 5, 2009 i have seen somewhere on this site before that somebody got 1 or 2 more ponies out of a drag axle over the stock one on a dyno because of less rotating mass matt Quote Link to comment Share on other sites More sharing options...
kawiking Posted August 8, 2009 Report Share Posted August 8, 2009 if u have a "drag " bike... then id save up and get a axle. i run a lonestar axle Quote Link to comment Share on other sites More sharing options...
Blewbyu Posted August 8, 2009 Report Share Posted August 8, 2009 I bought one cause its easier to load in the back of the truck Quote Link to comment Share on other sites More sharing options...
kawiking Posted August 8, 2009 Report Share Posted August 8, 2009 also remember u 'll need a 40mm carrier. or u might have to change the bearings and seals in a 35mm carrier to a 40mm for the drag axle Quote Link to comment Share on other sites More sharing options...
stroking Posted August 11, 2009 Author Report Share Posted August 11, 2009 I got a JJ&A gun drilled drag axle and it did help trim a little from my et's in 500ft dirt.As mentioned they are considerably lighter and allow for more adjustment of the rearend width. Steve what about a override.......think that will trim down the down 2tenths? Quote Link to comment Share on other sites More sharing options...
STINKYDELUXE Posted August 11, 2009 Report Share Posted August 11, 2009 what about a override.......think that will trim down the down 2tenths? I would get an override first, it is a must have if you drag race. the best investment I made Quote Link to comment Share on other sites More sharing options...
J-Madd Posted August 11, 2009 Report Share Posted August 11, 2009 I would get an override first, it is a must have if you drag race. the best investment I made x2. A new jj&a drag axle would be near the bottom of my list of things to do.... Only after you already had porting, override, lockup, etc. If you're maxxed out on mods to your current setup, and have the funds then I'd say go for it. I run them on all of mine. Quote Link to comment Share on other sites More sharing options...
