Henman80 Posted July 18, 2009 Report Share Posted July 18, 2009 Does anybody know if you can change the gear shifter seal form the outside or if u have to split the case. 99 banshee Thanks Quote Link to comment Share on other sites More sharing options...
Rodneya Posted July 18, 2009 Report Share Posted July 18, 2009 Yes you can change it from the outside, just a bit fiddly to get out. take care not to nick the shaft while doing it though. Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted July 18, 2009 Report Share Posted July 18, 2009 Take a screw, and run it several threads deep into the metal of the seal, grab it with a pair of pliers, and pull the seal out. Quote Link to comment Share on other sites More sharing options...
dragbanshee Posted July 18, 2009 Report Share Posted July 18, 2009 Does anybody know if you can change the gear shifter seal form the outside or if u have to split the case. 99 banshee Thanks When I got mine 97 it was leaking, I thought damn Im going to have to tear the motor down, no such thing. I just got a small wood screw and screwed it up in there carefully thinking I would just grab it with some plyers and work it out. Well the screw worked as an easy out and worked the seal out as I screwed it in, worked great! Quote Link to comment Share on other sites More sharing options...
