392 cub part out
here is the start of my part out.. first is a polished 392 cub cylinder.. it is like new with very little time, 68mm bore stock stroke, includes pistons head and dones.. all ready to bolt on and go.. it has 20cc domes setup for pump gas.. 900 plus the ride. will consider a partial trade on a set of stock cylinders on these.
NEXT are the intake, reeds and carbs.. the intake is a boss racing for 33-35mm carbs.. has a built in crossover also, 60.00.. asking 80.00 on the vforce reeds, and the carbs are 33mm pwk's. they have about 4 rides on them since bought new, they already have the easy springs installed, a stainless braided throttle cable, longer adjusters on the carbs caps, and brass idle screws still new in the package.. i also have some rubber boot adapters i will thow in if you are using a stock airbox, 300.00
are they ported and if so by who?
Sorry for the question. What jets are you running in you carbs? What temps and altitude? Reason for asking is that I have the same setup as you and I am battling to jet. Your help will be appreciated.
Id give you $50 shipped to 11787 for the intake if still avalible.
  • 3 weeks later...
  • 2 weeks later...
