The reed cages work great with all intakes but as with anything else perfectly matched is better.
I wasn't questioning their reed cage universality. I think you and I are on the same page. :geek:
Any one tired these? Do they work well? Do you use a rubber coating for the reed to seal/bounce against or is it just aluminum? How do they compare to stock ported cages? Looking for a good alternative to the vf2's for running nitrous.
no rubber, just aluminum, but no one has had a problem with it, and i believe the issue is gauranteed, but don't wanna put words in their mouth. much better design than ported stockkers, btw
I don't know how they work with nitrous but they should work great. Boyesen reeds, I believe work well with nitrous.
Jerry
Do they use banshee reeds or blaster reeds? The reeds will work with nitrous as long as they are not carbon fiber. I understand that you did some extensive testing on your cage/reed setup. Would it be cool if I shot you an email to sort of discuss findings and data? Thanks
Banshee reeds. Send a pm.
