BANSH-alena-jol-EE Posted July 11, 2009 Report Share Posted July 11, 2009 hello, i was in a rush so i just put a set of rings on the bitch...comp was way down at 85 & 83 and now still holds the same, the bike feels like shes hauling harder but no gain in comp??? shes a 04 first time she was apart, i guess i must need to get her bored out and some new pistons, i think the rubber coolant plugs were leaking a little bit, but i never changed them... Quote Link to comment Share on other sites More sharing options...
byrdmanracing Posted July 11, 2009 Report Share Posted July 11, 2009 hello, i was in a rush so i just put a set of rings on the bitch...comp was way down at 85 & 83 and now still holds the same, the bike feels like shes hauling harder but no gain in comp??? shes a 04 first time she was apart, i guess i must need to get her bored out and some new pistons, i think the rubber coolant plugs were leaking a little bit, but i never changed them... i would check the head and the reeds. the comp should be no lower then 85. for a fresh eng. u need around 100 at least Quote Link to comment Share on other sites More sharing options...
Drewski Posted July 11, 2009 Report Share Posted July 11, 2009 did you at least hone the cylinders before you put it back together? Quote Link to comment Share on other sites More sharing options...
Drewski Posted July 11, 2009 Report Share Posted July 11, 2009 you need to hone the cylinders in order for the rings to seat in properly. and if that doesn't help you probably need to bore them out Quote Link to comment Share on other sites More sharing options...
BANSH-alena-jol-EE Posted July 11, 2009 Author Report Share Posted July 11, 2009 sorry man, not totally fresh engine, i re used my pistons, which are 5 years old, but they looked mint, just got the cylinders honed and put in new rings reeds and head are good man, no leaks Quote Link to comment Share on other sites More sharing options...
Drewski Posted July 11, 2009 Report Share Posted July 11, 2009 hmm.... thats kinda fucked. whats your elevation? still you should be at least 100psi of compression Quote Link to comment Share on other sites More sharing options...
Drewski Posted July 11, 2009 Report Share Posted July 11, 2009 I would try taking a reading with another compression tester Quote Link to comment Share on other sites More sharing options...
Drewski Posted July 11, 2009 Report Share Posted July 11, 2009 oh ya, also if the threaded part of the comp. tester doesn't go all the way into the head(same length of the spark plug)you will get an inaccurate reading Quote Link to comment Share on other sites More sharing options...
BANSH-alena-jol-EE Posted July 11, 2009 Author Report Share Posted July 11, 2009 im at sea level Quote Link to comment Share on other sites More sharing options...
