SVT03 Posted July 11, 2009 Report Share Posted July 11, 2009 I just picked up a 2005 banshee and was wanting to change the oil but i need to know what kind of oil to put back in it? Quote Link to comment Share on other sites More sharing options...
Drewski Posted July 11, 2009 Report Share Posted July 11, 2009 I use gear saver 80 wt, but next time you post u might want to do a search first, this topic has been covered a million times Quote Link to comment Share on other sites More sharing options...
91/99 banshee Posted July 11, 2009 Report Share Posted July 11, 2009 hey thanks for asking this. i was wanting to know too. i tried to search it, but it kept saying error. so if you find out what to use, let me know. some peeps say you can use 40, but i am unsure. so let me know. Quote Link to comment Share on other sites More sharing options...
firebanshee Posted July 11, 2009 Report Share Posted July 11, 2009 I use type F transmission fluid, it has good lubricating qualities and grabbing agents built in it so your clutches don't slip. Quote Link to comment Share on other sites More sharing options...
SVT03 Posted July 11, 2009 Author Report Share Posted July 11, 2009 I use gear saver 80 wt, but next time you post u might want to do a search first, this topic has been covered a million times well being how it didnt bring anything up when I searched that's not going to do me much good..that's kinda why I started this thread Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 11, 2009 Report Share Posted July 11, 2009 (edited) There will be a few members telling you to do a search... I have been there, done that. Error. No results. Blah Blah Blah Post up, and learn. Some guys spend lots of time on here, like all day. So they get sick of these questions. They may never answer any of my questions ever again, oh well. They are stuck up and can go pound sand. You have a question, it needs answered. Plain and simple. They don't own the forum. The forum owners never complain about it... always the guys who are on all day, every day. And I can name a few. I use GearSaver 85 WT. Use only the best. I tried ATF Type F, and saw lots of wear in the clutch plates and tranny. Not with BelRay GearSaver though. ATF Type F users seeem to be drag racers. I seen them, talked with them, and even on here, looked at their sigs. Look at the guys who post they use ATF type F... MOSTLY, I repeat, mostly... drag racers. They run their bikes for 1, 2, 3, 10, etc. passes. Not much. They change often. Guys who ride, run their bikes hard, run good stuff. 3-5 passes on the track is not 8-10 hours in the dunes. Or... in my case, the coal hills. Don't let your bike come in second place. Use good oil. I asked many times in the past, and came to that conclusion after 1 hour with that fucking garbage in my tranny/clutch. While it might work for them, won't work for the everyday banshee owner Joe... Good luck. Tony Edited July 11, 2009 by TeamRealtreeHD Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted July 11, 2009 Report Share Posted July 11, 2009 That's a very interesting observation about TYPE of machine using atf. Might rethink about using it. What do you think about mixing gear saver+atf? Best of both worlds? Being computer dummy, search doesn't work to good for me. Can't seem to narrow search enoug, lol. "Example", don't need 25 pages of "Ported Stock Reed Cages". Just one pic of before + after. Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 11, 2009 Report Share Posted July 11, 2009 There will be a few members telling you to do a search... I have been there, done that. Error. No results. Blah Blah Blah Post up, and learn. Some guys spend lots of time on here, like all day. So they get sick of these questions. They may never answer any of my questions ever again, oh well. They are stuck up and can go pound sand. You have a question, it needs answered. Plain and simple. They don't own the forum. The forum owners never complain about it... always the guys who are on all day, every day. And I can name a few. I use GearSaver 85 WT. Use only the best. I tried ATF Type F, and saw lots of wear in the clutch plates and tranny. Not with BelRay GearSaver though. ATF Type F users seeem to be drag racers. I seen them, talked with them, and even on here, looked at their sigs. Look at the guys who post they use ATF type F... MOSTLY, I repeat, mostly... drag racers. They run their bikes for 1, 2, 3, 10, etc. passes. Not much. They change often. Guys who ride, run their bikes hard, run good stuff. 3-5 passes on the track is not 8-10 hours in the dunes. Or... in my case, the coal hills. Don't let your bike come in second place. Use good oil. I asked many times in the past, and came to that conclusion after 1 hour with that fucking garbage in my tranny/clutch. While it might work for them, won't work for the everyday banshee owner Joe... Good luck. Tony [/quote Saying that drag racers are the only ones that use ATF isn't a really fair statement. I mostly dune ride with some drag for fun. No competition or anything. Mostly just duning. I use ATF and have never had an issue. If you want to spend a little more coin to feel good about it get something synthetic like "Trick Shift". A little more costly and a good lubricant. I really doesn't matter as far as lubrication goes. Just about any oil will lub the tranny. What we are after is something that aids the clutch in not slipping. Personally, I have found that ATF works best for that. Maybe that's why you see a lot of drag guys using it due to the higher HP and Tq motors. SP Quote Link to comment Share on other sites More sharing options...
firebanshee Posted July 11, 2009 Report Share Posted July 11, 2009 There will be a few members telling you to do a search... I have been there, done that. Error. No results. Blah Blah Blah Post up, and learn. Some guys spend lots of time on here, like all day. So they get sick of these questions. They may never answer any of my questions ever again, oh well. They are stuck up and can go pound sand. You have a question, it needs answered. Plain and simple. They don't own the forum. The forum owners never complain about it... always the guys who are on all day, every day. And I can name a few. I use GearSaver 85 WT. Use only the best. I tried ATF Type F, and saw lots of wear in the clutch plates and tranny. Not with BelRay GearSaver though. ATF Type F users seeem to be drag racers. I seen them, talked with them, and even on here, looked at their sigs. Look at the guys who post they use ATF type F... MOSTLY, I repeat, mostly... drag racers. They run their bikes for 1, 2, 3, 10, etc. passes. Not much. They change often. Guys who ride, run their bikes hard, run good stuff. 3-5 passes on the track is not 8-10 hours in the dunes. Or... in my case, the coal hills. Don't let your bike come in second place. Use good oil. I asked many times in the past, and came to that conclusion after 1 hour with that fucking garbage in my tranny/clutch. While it might work for them, won't work for the everyday banshee owner Joe... Good luck. Tony Everyone is entitled to there opinion and i respect yours, but i do belive that automatic transmissions have way more moving parts and way more clutch packs in them than a banshee or any other quad has. Do you realize how much heat and abuse a automatic transmission takes, a torque converter alone makes about the same heat as a engine makes because they work by shearing oil.I have seen automatic transmissions go 100,000 + miles without changing the fluid although you shouldn't do this, so i don't think you shouldn't question the quality of ATF fluid it just comes down to personal preference. I also use ATF in my dune bikes not just my drag bike. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted July 11, 2009 Report Share Posted July 11, 2009 Point well taken about duner. Had a T-500 drag bike yrs ago only ran trick shift. Only prob ever was staged to long @ full throttle, clutch engaged (spun oil out?) , bike turned best time ever!! I also use atf as engine cleaner before oil change. Limited time of course! Quote Link to comment Share on other sites More sharing options...
91/99 banshee Posted July 11, 2009 Report Share Posted July 11, 2009 so when ya'll are talking atf, are you talking bout just the tranny, or what. i was talking bout changing the oil in the motor itself. does it just take one and that's it. motor and tranny together. i haven't owned a banshee long, so my bad for the all so obvious questions. Quote Link to comment Share on other sites More sharing options...
tonyown Posted July 11, 2009 Report Share Posted July 11, 2009 banshee are 2 stroke... the engine oil is in gas... so u dont have to change it as asked in this thread u just mix your gas with oil and burn it... I personally use motul 800 but there's a lot of oil u can use search button for this one you'll find a lot of post Quote Link to comment Share on other sites More sharing options...
91/99 banshee Posted July 13, 2009 Report Share Posted July 13, 2009 so the oil that you check by the kick start is the tranny oil or what. i just called the yamaha place, and they gave me yamalube 10 40. what do you guys think. Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 13, 2009 Report Share Posted July 13, 2009 so the oil that you check by the kick start is the tranny oil or what. i just called the yamaha place, and they gave me yamalube 10 40. what do you guys think. Yes, that is the tranny oil. 10/W40 is fine, some use 10/W30, 75W gear oil, 80W gear oil, ATF, etc, etc. The crankcase, bearings, and piston rings are lubricated by your 2 stroke mix. SP Quote Link to comment Share on other sites More sharing options...
x_doug_x Posted July 13, 2009 Report Share Posted July 13, 2009 i'm kinda glad someone started this topic, i decided to get royal purple gear oil it was 16 bucks for a bottle.... when i first got on my banshee the clutch plates were locked up from sitting, i rev'd it and put it in gear and they broke loose. i took it out and the clutches have slipped since i rebuilt the motor.. i never rode it before hand. coudl the royal purpel synthetic gear oil cause the clutches to slip? Quote Link to comment Share on other sites More sharing options...
