I know this topic has been discused already but i would like to hear some of alls input on this the bike came with 16 front and 39 rear guy i bought it from said it had a cub motor in it personally i believe these gears are to high cause regular banshee with pipes and stock carbs are out running me its and I have more accel. almost forgot I have 20/11/9 rear tires bought the frame seperate is no longer a cub. :down::confused:
what size cub? With stock cylinders id go with a 14 front with a 40,41,or42 rear. If its sttill a cub go with a 15front and a 42 or 43 rear :thumbsup:
first of all your thread is in the wrong section and is pretty hard to decipher so you might not get the replies you're hoping for.
i have a 421 cub, i'm running the same size tires and the same gearing as you because i ride on the beach a lot.
my cub hits top speed really quickly and that's 80+mph.
how long is the race, are you getting near the top of 6th?
if not gear that sucker down, there's no point in having all that speed if you have no use for it
Nope not a cub changed gears last night to a 14/40 its like a whole nother bike wants to come off the ground from 1st -4th pulls 6th with no problem . man that cub must have had some serious power to pull them old gears. After I posted the post relized i was in the wrong thread . Sorry :shoothead:
