topo Posted July 2, 2009 Report Share Posted July 2, 2009 (edited) hello does anyone know what step to take to remove the push lever? Edited July 2, 2009 by topo Quote Link to comment Share on other sites More sharing options...
toolucky Posted July 2, 2009 Report Share Posted July 2, 2009 you will need to remove the springs off of your clutch basket to relieve the tension from the actuator arm. Remove the left carb and push the spring off of the boss thats rite beside the clutch actuator arm and then it should slide out Quote Link to comment Share on other sites More sharing options...
blu01shee Posted July 2, 2009 Report Share Posted July 2, 2009 Mine has a case bolt that i had to remove because it had likea keeper or holder that ran over the top of the pusher Quote Link to comment Share on other sites More sharing options...
jbones Posted July 2, 2009 Report Share Posted July 2, 2009 you will need to remove the springs off of your clutch basket to relieve the tension from the actuator arm. Remove the left carb and push the spring off of the boss thats rite beside the clutch actuator arm and then it should slide out First thing i do is wash the motor real good so no dirt ends up inside ,mine had a small hold down bracket u unbolt from the case. U will also have to remove clutch cover and loosen clutch springs and ajustment rod and ball bearing and then push spring off and should slide out. Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted November 14, 2009 Report Share Posted November 14, 2009 sorry to dig up an old post but does anybody know the part number for the hold down, i lost mine. Thanks Cody Quote Link to comment Share on other sites More sharing options...
someone82 Posted November 15, 2009 Report Share Posted November 15, 2009 sorry to dig up an old post but does anybody know the part number for the hold down, i lost mine. Thanks Cody From bikebandit.com it is part number: 353409-001 - $6.76 Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted November 15, 2009 Report Share Posted November 15, 2009 From bikebandit.com it is part number: 353409-001 - $6.76 Bike Bandit part numbers are NOT Yamaha numbers, the Yamaha numberis 90462-16130-00. Quote Link to comment Share on other sites More sharing options...
