Meat Posted July 6, 2009 Report Share Posted July 6, 2009 Same place as you. QuickSand Quote Link to comment Share on other sites More sharing options...
Chariot Performance Posted July 6, 2009 Author Report Share Posted July 6, 2009 Same place as you. QuickSand Thanks for the pictures. The 250r caliper looks a lot like the earlier yfz450 calipers. We are making a lot of progress on the caliper design. I expect we will have some done in about 6 weeks. Thanks again for all the info and suggestions. Quote Link to comment Share on other sites More sharing options...
FireHead Posted July 6, 2009 Report Share Posted July 6, 2009 I have the same exact setup as Flash & Flare has. Wanna see some pictures :cool: Follower....... :biggrin: Quote Link to comment Share on other sites More sharing options...
FireHead Posted July 6, 2009 Report Share Posted July 6, 2009 I know for the drag guys they remove front brakes. How many people would be interested in dual piston front brakes as well? Desert guys? Asphalt guys? The YFZ450 front setup will probably cover most folks needs on the front.... I didn't run front brakes on my hill/drag bike and the OEM Banshee caliper wasn't enough to slow it down....... A bigger rear caliper that is a direct bolt-on is probably what most folks need. You need to probably use some type of OEM pads from a sport bike to make the product useful. Some of the Formula Atlantic cars run pad from a litre bike on their diff. outputs in an integrated opposed 3 piston caliper design (6 pistons total). I could see making a single caliper setup like that work pretty well, but plunge EDM'ing or gun drilling the fluid ports is a design drawback for such a long style of caliper. :geek: Quote Link to comment Share on other sites More sharing options...
Chariot Performance Posted July 6, 2009 Author Report Share Posted July 6, 2009 The YFZ450 front setup will probably cover most folks needs on the front.... I didn't run front brakes on my hill/drag bike and the OEM Banshee caliper wasn't enough to slow it down....... A bigger rear caliper that is a direct bolt-on is probably what most folks need. You need to probably use some type of OEM pads from a sport bike to make the product useful. Some of the Formula Atlantic cars run pad from a litre bike on their diff. outputs in an integrated opposed 3 piston caliper design (6 pistons total). I could see making a single caliper setup like that work pretty well, but plunge EDM'ing or gun drilling the fluid ports is a design drawback for such a long style of caliper. :geek: As of now I plan on making some two piston and four piston all opposing rear calipers. My guess is that the dual piston will work just slightly better than a dual piston yfz450 caliper and the four piston will satisfy all other requirements. Just a guess so far but we'll see. Thanks Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 6, 2009 Report Share Posted July 6, 2009 Let me know when I can stop by to pick mine up... Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted July 6, 2009 Report Share Posted July 6, 2009 Is the Banshee master and reservior capable of producing the power and fuild capacity needed to support such an application? Quote Link to comment Share on other sites More sharing options...
FireHead Posted July 7, 2009 Report Share Posted July 7, 2009 Is the Banshee master and reservior capable of producing the power and fuild capacity needed to support such an application? That is a good question. It all depends on the size of the piston used. It is definitely a design challenge. :geek: Quote Link to comment Share on other sites More sharing options...
Chariot Performance Posted July 7, 2009 Author Report Share Posted July 7, 2009 Is the Banshee master and reservior capable of producing the power and fuild capacity needed to support such an application? I believe they will work fine. We will see! Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted August 25, 2014 Report Share Posted August 25, 2014 QUOTE (Bansh-eman @ Jul 6 2009, 07:24 PM) Is the Banshee master and reservior capable of producing the power and fuild capacity needed to support such an application? I believe they will work fine. We will see! what was the final outcome of this project ? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 26, 2014 Report Share Posted August 26, 2014 On the shelf next to the carbs? It would be sweet but not practical I bet. Although, some drag guys would love an ultra light with rear. Or some type of zero drag that doesn't fall off. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 29, 2017 Report Share Posted November 29, 2017 Could a Billit dual piston caliper be lighter then the 250r or new 450stuff or even the popular Brembo? Quote Link to comment Share on other sites More sharing options...
TrickedCarbine01 Posted November 29, 2017 Report Share Posted November 29, 2017 Something like this would be tits, but those Beringer brakes are probably 2-3K. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Chariot Performance Posted December 5, 2017 Author Report Share Posted December 5, 2017 Yes they are on the shelf next to the carbs. We have been swamped the last 3 years and the carb is a big big project. We may pick up both these projects in the next year. Jerry Quote Link to comment Share on other sites More sharing options...
