Chariot Performance Posted June 26, 2009 Report Posted June 26, 2009 This impeller kit will help with the most stubborn engine temperature problems. Ultra Flow impeller Quote
dco3100 Posted June 26, 2009 Report Posted June 26, 2009 damn I love the quality in all your parts!! Quote
Bill Posted June 26, 2009 Report Posted June 26, 2009 About time somebody came up with a better design, man you guys come up with some awesome stuff! I want one bad. Quote
KlotzBanshee Posted June 26, 2009 Report Posted June 26, 2009 (edited) Nice piece :thumbsup: good job Edited June 26, 2009 by AssWhore Quote
robert0762 Posted June 26, 2009 Report Posted June 26, 2009 I have heard of actually moving the coolant too fast. it wont pick up the heat and have enough dwell time in rad to disperse it. Not saying that this is what you r doing just asking if this is or can be an issue in a banshee? I think its a gret product none the less and the cover is nice as well I will def be picking one up . Actually been waiting for it since I seen post about one coming soon. Do you guys plan on making a head? One that diverts water down into the cylinders would be awsome. I saw a add on for a pro design one but have heard very little about it Quote
BSHEE400 Posted June 26, 2009 Report Posted June 26, 2009 wow that ultra impeller looks meaty, i want one lol Quote
jbooker82 Posted June 27, 2009 Report Posted June 27, 2009 Do you guys plan on making a head? One that diverts water down into the cylinders would be awsome. I saw a add on for a pro design one but have heard very little about it The guy that makes the sling shot lockups makes a top cover for the Prodesign head that does that. Quote
jbooker82 Posted June 27, 2009 Report Posted June 27, 2009 What does the back of the water pump cover look like? What makes the waterpump work is the housing that it sits in. So if your water pump cover doent match the aluminum clutch cover then it wouldn't really be worth it. All it will do is spin the coolant in the clutch cover instead of forcing it up into the head. Quote
FireHead Posted June 27, 2009 Report Posted June 27, 2009 The guy that makes the sling shot lockups makes a top cover for the Prodesign head that does that. I think there are a couple other folks out there that are making the smae thing..... If I recall, Trinity even has something like that (not sure if it's on the site or not). Quote
FireHead Posted June 27, 2009 Report Posted June 27, 2009 What does the back of the water pump cover look like? What makes the waterpump work is the housing that it sits in. So if your water pump cover doent match the aluminum clutch cover then it wouldn't really be worth it. All it will do is spin the coolant in the clutch cover instead of forcing it up into the head. I have the same questions. I think I am missing something when it comes to undetanding the product. :geek: Quote
KaosBanshee44 Posted June 27, 2009 Report Posted June 27, 2009 Looks like it has more fins on it to transfer the water faster than other impellers especially the stock impeller. Quote
FireHead Posted June 27, 2009 Report Posted June 27, 2009 Looks like it has more fins on it to transfer the water faster than other impellers especially the stock impeller. If I were not making my own, I would probably buy one just to be diffferent, if nothing else...... It's definitely $100 cool. I am curious as to what the numbers are behind the increased flow, and how much of a cooling difference it makes. :geek: Quote
NickisGod Posted June 27, 2009 Report Posted June 27, 2009 wow that things big. does it even fit in the water pump housing? Quote
jbooker82 Posted June 28, 2009 Report Posted June 28, 2009 wow that things big. does it even fit in the water pump housing? It looks like it has an extended cover. The cover needs to continue the contours of the water pump housing in order for the pump to operate efficiently, other wise it will just cavitate / aireate the coolant. Quote
jbooker82 Posted June 28, 2009 Report Posted June 28, 2009 A small bolt / drain plug would be nice so you have an ez drain cover. Quote
