fresh rebuild
jse28
anyone have any advise?
Could be lots of things, what have already checked?
I would make sure it's getting spark.
Check carbs
Check REEDS
Compression check dead cylinder
More than likely it's in the carb/reed area somewhere.
When the bike fires on once cylinder stand up on the pegs and shake it back and forth from one side to the other. I find this sometimes brings the other cylinder to life. Could be a sticking float or something like that.
Plug wet with gas?
Spark plug gap correct?
Pickup coil gap correct? (althought this would probably affect both cyls I would check it, and set it if you didn't)
Just double check everything and you'll find it.
