banshee head stud
No, don't run it like that, unless you want to redo your top end in the first 10-15 mins of riding.
Just use pb blaster, let it soak in and use 2 nuts to get if off if threes enough threads for 2 to fit on, which it doesn't look like there is.
If not then the heat from a torch is your friend.
Edited by savage420
yeah theres no more threads on there so i might have to use the torch, what if the torch doesnt work what else can i do??
Torch will work, get it HOT though.
And use something that will clamp on real tight to the stud to spin it out.
:beer:
How the hell did you break it off in the first place man? :whistling:
thanks for the help guys, it does come out conterclockwise right?
Yes. Counterclockwise left :laugh:
How did you break it ? :ermm:
Edited by savage420
overtorqed it with a torque wrench that didnt work, found out the hard way lol.
WOW!!! How much do you think you torqued them too, 100ftlbs? :yelrotflmao:
Edited by savage420
