swhitey917 Posted June 24, 2009 Report Posted June 24, 2009 Ok guys I have been battling an on going problem since i got my banshee. On the top of my left carb the threads that the T.O.R.S thing screws onto is stripped and I can't tighten it down all the way. I can hand tighten it pretty tight buy i cant tighten fully with pliers or anything. After riding for a while the vibrations rattle the top off and then the quad revs really high because the top popped off. Is there anything I can do to fix this from happening or do i have to get another carb? Quote
blu01shee Posted June 24, 2009 Report Posted June 24, 2009 Ok guys I have been battling an on going problem since i got my banshee. On the top of my left carb the threads that the T.O.R.S thing screws onto is stripped and I can't tighten it down all the way. I can hand tighten it pretty tight buy i cant tighten fully with pliers or anything. After riding for a while the vibrations rattle the top off and then the quad revs really high because the top popped off. Is there anything I can do to fix this from happening or do i have to get another carb? Ditch the tors and get the elimantor kit its pretty reasonable Quote
swhitey917 Posted June 24, 2009 Author Report Posted June 24, 2009 Ditch the tors and get the elimantor kit its pretty reasonable Even if i did that, It would not solve my problem. I believe the threads on the top of my carb are messed up not the threads on my tors system. So even if i got new carb tops i would still have the same problem Quote
blu01shee Posted June 24, 2009 Report Posted June 24, 2009 Even if i did that, It would not solve my problem. I believe the threads on the top of my carb are messed up not the threads on my tors system. So even if i got new carb tops i would still have the same problem Sorry bout that miss understood you but i have seen stock carbs on hear for a decent price Quote
swhitey917 Posted June 24, 2009 Author Report Posted June 24, 2009 Anybody else have some advice? Quote
pr0blumz Posted June 24, 2009 Report Posted June 24, 2009 Anybody else have some advice? I got a stock carb you can have if you pay the shipping. Quote
AKheathen Posted June 24, 2009 Report Posted June 24, 2009 try a thread file thread files are a godsend Quote
dajogejr Posted June 24, 2009 Report Posted June 24, 2009 Thread file is cheaper. A new/used stock carb will work too. remove the TORS while you're at it. In a pinch, I've used Duct Tape to secure it....but obviously, that's not the best way. Stock carb caps are garbage...very, very fine threads and easy to strip with ham hands. Quote
yamahaman244 Posted June 24, 2009 Report Posted June 24, 2009 Thread file is cheaper. A new/used stock carb will work too. remove the TORS while you're at it. In a pinch, I've used Duct Tape to secure it....but obviously, that's not the best way. Stock carb caps are garbage...very, very fine threads and easy to strip with ham hands. Got the same thing left carb is strip i just leaft it proby aint a good thing Quote
VegasJeff Posted June 24, 2009 Report Posted June 24, 2009 Anybody else have some advice? I had the same problem. I knew I was buying new carbs a few months down the road,so I just put some JB weld under the cap and screwed it down,it worked till I upgraded. Quote
AKheathen Posted June 24, 2009 Report Posted June 24, 2009 Thread file is cheaper. A new/used stock carb will work too. remove the TORS while you're at it. In a pinch, I've used Duct Tape to secure it....but obviously, that's not the best way. Stock carb caps are garbage...very, very fine threads and easy to strip with ham hands. ham hands? is that like sausage fingers? :biggrin: i have a left carb body. $20 if anyone's interested. anyone have a problem with the eliminator caps being sloppy? Quote
yamahaman244 Posted June 24, 2009 Report Posted June 24, 2009 ham hands? is that like sausage fingers? :biggrin: i have a left carb body. $20 if anyone's interested. anyone have a problem with the eliminator caps being sloppy? me my hole left carb wiggles back and forth Quote
AKheathen Posted June 24, 2009 Report Posted June 24, 2009 they tigten down fine without slop, just seem like alota play untill it huts the gasket Quote
