01bansheerider Posted June 19, 2009 Report Share Posted June 19, 2009 Ok, well i am new to this forum so i do have one question. If I were to buy the fmf power core2 silencers do i have to buy the carbs with it? Or can I just buy the silencers? I know it's kind of dumb not to buy the carbs but i cant really afford that right now... Quote Link to comment Share on other sites More sharing options...
black sunshine Posted June 19, 2009 Report Share Posted June 19, 2009 Are you getting the head pipes/expansion chambers as well? You do not have to buy carbs, you will have to change your jetting if you currently have stock pipes. Quote Link to comment Share on other sites More sharing options...
01bansheerider Posted June 19, 2009 Author Report Share Posted June 19, 2009 Well really all i know so far is im getting just the silencers... And yes, i have the stock pipes now. Everything is stock so i know i have to rejet. So should I get what you said? Quote Link to comment Share on other sites More sharing options...
black sunshine Posted June 19, 2009 Report Share Posted June 19, 2009 IDK if just the silencers will change anything dramatically, I'll let someone else chime in. Learn to do a plugchop to dial in your main jets. Look up FASTOYS, he has the link in his signature. If you have not yet purchased the silencers, I'd hold off. Scrounge around on here; there are alot of good deals on used pipes/silencers, as well a a new air filter setup to let that baby breathe! Quote Link to comment Share on other sites More sharing options...
01bansheerider Posted June 19, 2009 Author Report Share Posted June 19, 2009 Ok, thanks alot. I have not yet bought the pipes. I'll do what you said. once again thanks! Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 19, 2009 Report Share Posted June 19, 2009 Changing the silencers wont do much for you. I dont know if they will even match up to the stock expansion chambers. You need to buy it as a set. Look for some used FMF's Pro Circuits, DMC's, or Toomey's. Quote Link to comment Share on other sites More sharing options...
01bansheerider Posted June 20, 2009 Author Report Share Posted June 20, 2009 So may i have a list of everything i should get for pipes to get more power? and what pipes would you recommend? Quote Link to comment Share on other sites More sharing options...
