yamahaman244 Posted June 17, 2009 Report Share Posted June 17, 2009 on my shee went i start it up it leaks antifreze from one of the head bolts then if i ride it down by your carbs there is taht balance tube witch is silver there is antifreze down in there coming out not alot but u can see it any ideas please need awsores asap Quote Link to comment Share on other sites More sharing options...
BoostedRex Posted June 17, 2009 Report Share Posted June 17, 2009 on my shee went i start it up it leaks antifreze from one of the head bolts then if i ride it down by your carbs there is taht balance tube witch is silver there is antifreze down in there coming out not alot but u can see it any ideas please need awsores asap Is it a new motor? Aftermarket head? Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted June 17, 2009 Author Report Share Posted June 17, 2009 Is it a new motor? Aftermarket head? No it has a stock head on it and we just did a top end on just the one side and it is the right side that we redone and that is the side it is doing it on to any ideas Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted June 17, 2009 Author Report Share Posted June 17, 2009 No it has a stock head on it and we just did a top end on just the one side and it is the right side that we redone and that is the side it is doing it on to any ideas Anyone have any ideas Quote Link to comment Share on other sites More sharing options...
AKheathen Posted June 17, 2009 Report Share Posted June 17, 2009 did you remember the rubber plug in the bottom of the cylinder? did you retorque the head after a few heat cycles? Quote Link to comment Share on other sites More sharing options...
BoostedRex Posted June 17, 2009 Report Share Posted June 17, 2009 No it has a stock head on it and we just did a top end on just the one side and it is the right side that we redone and that is the side it is doing it on to any ideas Did you take it off in the proper sequence, and retorque it in the correct order? If you don't do it correctly you could warp the head. And like AKheathen said you have to heat cycle it and retorque everything again. Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted June 17, 2009 Author Report Share Posted June 17, 2009 did you remember the rubber plug in the bottom of the cylinder? did you retorque the head after a few heat cycles? okwhat is the rubber plug thing do u guys have any pictures or were i can find wat it looks liek what would that do if the guy didnt put that in and i didnt after the heat cycle but why would there be antifreze by the balance tube thing Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted June 17, 2009 Author Report Share Posted June 17, 2009 okwhat is the rubber plug thing do u guys have any pictures or were i can find wat it looks liek what would that do if the guy didnt put that in and i didnt after the heat cycle but why would there be antifreze by the balance tube thing Ok what does this plug look like and were does it go and what does it help do Quote Link to comment Share on other sites More sharing options...
AKheathen Posted June 17, 2009 Report Share Posted June 17, 2009 ok, the rubber plug goes in the bottom of the cylinder before you put it on, but i just realized that the balance tube is above the head. the coolant hose goes down through it, though. you need to replace the head gasket. it's probably all coming from there. don't forget the seequence and retorque. you'd be amazed how loose the nuts get, especially the front. Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted June 17, 2009 Author Report Share Posted June 17, 2009 ok, the rubber plug goes in the bottom of the cylinder before you put it on, but i just realized that the balance tube is above the head. the coolant hose goes down through it, though. you need to replace the head gasket. it's probably all coming from there. don't forget the seequence and retorque. you'd be amazed how loose the nuts get, especially the front. Ok ya when I start it it like blows or runs some antifreeze down the one side of the jug and it's just the one side then later I just went out there and put my one hand the one were it was leaking and I termed it with my hand and could antifrzze get into your tranny oil Quote Link to comment Share on other sites More sharing options...
AKheathen Posted June 17, 2009 Report Share Posted June 17, 2009 if antifreeze is in your tranny oil, then you have a bad water pump seal Quote Link to comment Share on other sites More sharing options...
TNTS355 Posted June 17, 2009 Report Share Posted June 17, 2009 on my shee went i start it up it leaks antifreze from one of the head bolts then if i ride it down by your carbs there is taht balance tube witch is silver there is antifreze down in there coming out not alot but u can see it any ideas please need awsores asap Or you could have put your head gasket on upside down. Take it off mark the other side with a light scratch. Place in a pan of water and boil for 10 mins. Replace the opposite way you had it on. I know this sounds weird but it works. Its hard to see but the stock head gasket has a slight rise on it and should be placed on the top and not on the bottom. Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted June 17, 2009 Author Report Share Posted June 17, 2009 Or you could have put your head gasket on upside down. Take it off mark the other side with a light scratch. Place in a pan of water and boil for 10 mins. Replace the opposite way you had it on. I know this sounds weird but it works. Its hard to see but the stock head gasket has a slight rise on it and should be placed on the top and not on the bottom. So that makes sence to u guys about it running down the jug and what about the balance tube if the head gasket is bad why would it Get into there ? Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted June 18, 2009 Author Report Share Posted June 18, 2009 So that makes sence to u guys about it running down the jug and what about the balance tube if the head gasket is bad why would it Get into there ? ?????? Quote Link to comment Share on other sites More sharing options...
BoostedRex Posted June 18, 2009 Report Share Posted June 18, 2009 On the tube that goes between your carbs and into your clutch cover there are 2 O-rings and a clip. On mine I had the clip get bent when I put it on and I got a shitload of water in my tranny. I just bought a new clip and O-rings. Problem solved. Quote Link to comment Share on other sites More sharing options...
