Drewski Posted June 16, 2009 Report Share Posted June 16, 2009 WTF went riding and now I have a knock in the right side of mr crank case. I chose to ride it after I noticed it and it still works great but I don't want to fuck it up. i'm thinking it might be the water pump as I have not changed the pump to a billet but I'm not sure. if anyone has any ideas please fell free to reply. The quad is a 2007 if that helps. Quote Link to comment Share on other sites More sharing options...
gregrob Posted June 16, 2009 Report Share Posted June 16, 2009 I doubt it is the water pump. Could be the clutch basket coming loose if it's on the right side of the engine. When the flywheel comes loose it sounds like that as well... but that's on the left. Does it go away with rpm, or get worse? Is there also a vibration present? Pull the clutch cover off and do a good visual inspection before you keep riding it and damage something further. Quote Link to comment Share on other sites More sharing options...
Drewski Posted June 16, 2009 Author Report Share Posted June 16, 2009 thanks for the reply. yes it does sort of go away when revving it up and no there is no viberation Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 16, 2009 Report Share Posted June 16, 2009 Could be the big nut that holds the PTO gear on the side of the crank. I've had those come loose and grind against the clutch cover just below the water pump and it makes a horrible noise. Pull your clutch cover and check your water pump gear, water pump itself... pretty much everything. Do a compression check while you're working on it too... Gregrob is right, check the flywheel. Noises can transfer through the crank and be misleading. - jared Quote Link to comment Share on other sites More sharing options...
banshee_terror_ Posted June 16, 2009 Report Share Posted June 16, 2009 i had ayz250 that did that except im pritty sure it was a rod nock Quote Link to comment Share on other sites More sharing options...
liveordie72089 Posted June 16, 2009 Report Share Posted June 16, 2009 If I were you I would stop riding it. Take the engine off and check everything. Better to catch it at this state then a rod going through your side case. I always look at the worse case scenario just so it doesn't get that worse lol. It sounds like either you blew a bearing in your crank like I did. Is it at the bottom? If could be The rod. So check it out. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 16, 2009 Report Share Posted June 16, 2009 Could very well be a broken clutch fiber. Stop riding it, as said.. When it comes to repairs. Pay a little now, or a lot more later. Quote Link to comment Share on other sites More sharing options...
robert0762 Posted June 16, 2009 Report Share Posted June 16, 2009 My flywheel was loose and it sounde like it was coming from the right side and you didnt hear it at throttle only when idleing Quote Link to comment Share on other sites More sharing options...
Drewski Posted June 17, 2009 Author Report Share Posted June 17, 2009 hey thanks for all of the reply's i'm going to pull her apart tonight. Quote Link to comment Share on other sites More sharing options...
Drewski Posted June 18, 2009 Author Report Share Posted June 18, 2009 turned out to be that a tooth off of the gear behind the clutch broke off. thanks for the help anyway! Quote Link to comment Share on other sites More sharing options...
