+2 swinger? quick question
mofoka
Going from stock to a +2 swingarm...
1. do I need to extend the brake line?
2. how many more links do I need to add to the chain?
3. can i get away with a stock shock
1. I would but you can get it to work without you just better have a spare in case it snags something.
2.depends on sprocket size I added 5 for a 14 in front and 4 for a 13 in front.
3. I ran a stock shock for a bit it worked fine but it was a recently recharged and rebuilt shock set to the hardest setting . So it depends on how soft you can handle it being.
so maybe on the brake line...
will I have much luck re valving the shock or is it necessary to re spring too.
*The shock is mostly about the the spring, not the valving. To do it 100% correct, you would need to do both, but with a +2" arm, a spring will get you most of the way there if you have to do anything at all.
*Your brake line should reach.
*The chain depends on what gearing you are running, but 6 links will cover nearly anything possible (you can always knock a few off).
