Coolant
50/50 auto coolant / water (denatured/boiled) works. If overheating is a issue you can try the expensive stuff and/or an additive.
ok, let me dispell a myth real quick. boiling/microwaving/filtering water is not the same as distilled/"denatured" water. period. the deistilling process is the same as making alchohol or fuel. it is evaporated, collected as a vapor, then returned into a liquid, leaving the minerals and chemicals behind. pure water. the other methods only kill biological content, but still leave the harmfull electrolytic and corrosive deposits commonly found in water.
that beind said, i, prsonally am an advocate for dex-cool because of it's superior lubricity, and aditives. however, i wouldn't blink twice about recomending engine ice, or water wetter in any combonation. the bottom line is, that whatever you choose, make sure it is in good condition. every coolant will turn from good/great to a harmfull acid over time. 2-3 years on conventional, and 5-6 years on dex.
