power gains with new top end
you might be able to get away with new rings!!!! but you can also get a head that allows you to change domes to bring up the compress and the compression from 90 to 150 will make a big diff...but pull the head and look at the pistons...pull the jugs and mic out the jugs and pistons. someone should have spes on how much wear. and if you are in the ball park you should be able to put new rings on and go!!! if money is tight try the rings first and then if that doesn help you will need to bore over one and get new pistons to that bore. if money isnt a prob then send off the jugs to get ported and new pistons and you will be a raped ape
I wouldnt throw in a head and domes to try to raise the compression. That isnt a solution, the engine definately is going to need some work. But yeah, you want to pull the jugs and measure the bore, it is detailed in Clymers, you might be able to get away with rings and a hone.
i definately agree, at 90 psi,your in need of a new top end for sure. dont test your luck with new rings,,,it wont cost that much more to bore it and put new pistons in it,then atleast u will have piece of mind that u will be safe from blowing your motor.....
