fyrmn14 Posted June 13, 2009 Report Share Posted June 13, 2009 Ok, so I just purchased some new cylinder jugs I am going to be swapping out on my bike and was wondering if I could get some advice on what carb size everyone thinks I should go with. I was thinking 35mm, but wondering if I should go bigger than that. Also was looking at the keihin airstrikers. Here is what the end result of the engine is going to be. Trinity Stage 3 porting 70.45 mm pistons Stock crank Coolhead with domes that I will be able to roughly run 95-100 octane gas at 4000-6000 above sea level. Vfroce 3 reeds and spacers CPI small-bore in frame pipes Thank you in advance for your info. Quote Link to comment Share on other sites More sharing options...
Scott M Posted June 13, 2009 Report Share Posted June 13, 2009 "Bigger is better" Like I always say sometimes but not in this case, Just trying to save you some time and $$.. 32mm/33PWK is plenty on gas, anymore and you risk #1 lower throttle response #2 losing some bottom-end. You could even get away with stocks bored to 28's... if money is an issue. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 14, 2009 Report Share Posted June 14, 2009 I would go with pwk33 boss intake and 10deg pod filters Quote Link to comment Share on other sites More sharing options...
toolucky Posted June 14, 2009 Report Share Posted June 14, 2009 Ok, so I just purchased some new cylinder jugs I am going to be swapping out on my bike and was wondering if I could get some advice on what carb size everyone thinks I should go with. I was thinking 35mm, but wondering if I should go bigger than that. Also was looking at the keihin airstrikers. Here is what the end result of the engine is going to be. Trinity Stage 3 porting 70.45 mm pistons Stock crank Coolhead with domes that I will be able to roughly run 95-100 octane gas at 4000-6000 above sea level. Vfroce 3 reeds and spacers CPI small-bore in frame pipes Thank you in advance for your info. I would goahead and just get tha stage 4 porting. You will wish you did Quote Link to comment Share on other sites More sharing options...
