painting frame
shit you guys were right it can apart super easy. now my question is what can i get powdercoated? anything i want or are there limits?
As far as I know, you can powdercoat anything thats metal, without any rubber parts or lubricant. If there is rubber or lubricants in the part it will have to be removed. For example, I just got my rear brake caliper coated and all the rubber seals and brake fluid had to be completely free from the assembly. The reason being is because after they spray the powder on the part, it has to get baked in an oven at 400 degrees, so anything unable to withstand that kind of temperature must be removed.
You can coat anything from your brake pedal, shifter, a-arms(for these you have to remove the rubber boots on the balljoints), swingarm, etc. Pretty much anything you think will look nice with a glistening mettalic color :cool:
