Sock recharge in Ft Worth area?
pecanfmr
Where can I get a set of Works front shocks recharged in the Ft. Worth area. I dont think anyone does things like that in my littlle town and I will be going up there this weekend. Thanks!
-RM
Edited by pecanfmr
There is more then just adding N2 to the shocks. Did they let them selfs out our did you let it out. I did you change the oil in the shocks? and all in all any welding shop can and should be able to fill them back up
I will check arounnd at some of the welding shops here. Im new to the aftermarket shock world but my friend had not used these much since the fluid was changed and I just wanted to make sure the nitrogen pressure was where it is supposed to be before I install these. I understand that 250psi is the correct pressure. Thanks for the help!
-RM
  • 1 month later...
