lodown Posted June 8, 2009 Report Share Posted June 8, 2009 Ok my shee doesn't want to idle on both cylinders. I can give it some throtal and you can here the left side start to fire but when you let it back to idle its only running on the right side. I pulled the choke just a little to see if it was getting gas and then i can see fuel dripping out the tail pipe. I have cleaned the carbs new float needles jets and it still wont idle on both cyl only the right. I have checked the reeds and there seemed good. I have even switched the plug wires and still only the right side fires at idle. I'm stumped as to what the hell is the prob. I dont have the tors at all and the carbs are sync with each other. Anybody know what could be the problem could be or have some advise would be realy appreciated thanks. I also did a comp check and both cyl are at 110 psi. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted June 8, 2009 Report Share Posted June 8, 2009 Swap carbs and if it does it still is not a carb prob. Ck compression Quote Link to comment Share on other sites More sharing options...
lodown Posted June 9, 2009 Author Report Share Posted June 9, 2009 Ok I switched carbs to the other sides and the problem went to the other cylinder. What is causing this carb to let to much fuel through? I have put new jets, floats and float needle seats, cleaned the carb a number of times and nothing seems to help. anybody have a clue to what the hell is up with this carb? Quote Link to comment Share on other sites More sharing options...
ziegman Posted June 10, 2009 Report Share Posted June 10, 2009 Make sure slides are not in backwards Quote Link to comment Share on other sites More sharing options...
lodown Posted June 10, 2009 Author Report Share Posted June 10, 2009 I have checked all of that. The floats, jets, slides, blew air through all the passages but it still just dumps way to much fuel. Quote Link to comment Share on other sites More sharing options...
INFINITIED Posted June 11, 2009 Report Share Posted June 11, 2009 I have checked all of that. The floats, jets, slides, blew air through all the passages but it still just dumps way to much fuel. change the needle and ceat !!! ... do both sides the other will be next (its just as old), get vito's or orignal needle and ceats they are the best!! this is your problem! Quote Link to comment Share on other sites More sharing options...
lodown Posted June 11, 2009 Author Report Share Posted June 11, 2009 I put new float needles and seats because it was leaking out the over flow tubes and running the same. But now it just runns the same, on one cyl at low rpm's, and not leaking out the over flows anymore. Could the choke plunger be bad or leaking fuel past it? If so which part of it do i check? Thanks!! Quote Link to comment Share on other sites More sharing options...
