IS 64.80 Acceptable bore for a set of 64.75 pistons?
Ive measured several times, and I keep getting 64.80mm. Is this acceptable with a light hone (no deep scratches) to drop in a set of wiseco or other (recommend brand) pistons that are for a 64.75 bore. Current pistons are toast. Maybe im being over careful, but I dont want to bore if i dont have to, but I dont want it to blow up or run like $hit either!
Simple question for an experienced builder.
Thanks
Brian
The only way to be sure its right is to take them to a good machinist or someone that bores cylinders,and have them check it out.
Unless your really sure on how to measure them i would not chance it.
Word.
You need to have a bore gauge or a proper ID micrometer.
you will need to get the cylinders mic'ed up for taper and out-of-round. also, if your cylinders measure up to be 64.8mm and the pistons measure up to be 64.75mm, then you are getting a piston to cylinder clearance of .05mm, which is .002". maybe a little tight, if running wiseco pistons??
and the rings do the sealing, not the pistons, so don't think that the pistons are what causes the blow by.
Edited by mopar1rules
Anybody have a link on how you check taper and for out of round? I have a 2"-12" Starrett ID mic set. And ima machinist so i can possible get gauges from work.
I took them to the machinist, he checked them, and said they looked good and consistent. So, im going to order some pistons, probably the ones in the link below.
Ive got my current problem taken care of, but for future reference, when I order a set of pistons... say for example RJATV Ebay Wiseco 64.75 piston set
Are the pistons going to be 64.75, or should the bore be 64.75, or what, im kinda confused!? If the bore is supposed to be 64.75, then anything over that is wear, or is it a common practice to give them a little more space for clearance?
you need to have the bores matched to the pistons, to have the correct piston/cylinder clearance. you have to have some clearance in there. you can't have a piston that measures 64.75mm for example and a bore that measures 64.75mm. you will have seizure within minutes of running, if you get the piston to fit inside the bore ok, seeing as that would be a "size-on-size" fit. you need to have like .003" clearance, for stock bore and stock cast pistons. larger pistons and forged pistons, require more clearance. the bore will always be a few thousandths larger in diameter, than the piston, to allow room for the piston to "grow/expand", when it gets warm while running. understand? if i'm not mistaken, the pistons should measure the 64.75mm or whatever is stamped on the domes, and the bore is going to be a few thousandths over that.
for measuring bore diameters and taper, you take measurements at 3 points thru the bore. you measure at approx 1/2" down from the cylinder deck, straight across where like the wristpin would be and then 90* from that measurement. then do the same in the middle of the cylinder bore and then again at like 1/2" up from the cylinder bottom. compare the measurements throughout to compare and find out the taper and out-of-round. out of round should be no more than .0005" and the taper like no more than .002". hope this helps. maybe someone else can explain it better than me.
Go to Wiseco's website and pu;l up the bore and piston spec.'s out of their catalog. :cool:
Wiseco Part#: 513M06475
Product Type: Single Pistons
Description: YAM RZ350/BANSHEE PRO-LITE 2549CD
Displacement: 355cc
Bore - Standard: 64.00mm
Bore - Actual: 64.75mm
Bore - Oversize: 0.75mm
Stroke: 54.00mm
Cylinders: 2
Note: Pro-Lite
Note: Liquid cooled
Installation notes...It doesn't seem to tell me what Im looking for, but it is interesting! Drill 2 holes in my new pistons! Is this true!?
Wiseco M series Piston Install Inst.
90Bansheedude, you quoted me and didnt answer my question. If you scroll down you can click add replay if you dont need to quote something.
Thanks mopar1rules. That does make sense. I should of know that's how you measure the taper. It's common sense, heh. Just needed to know the tolerances of course. I dont and my shop doesnt have anything that measure
