wacko2000 Posted June 4, 2009 Report Share Posted June 4, 2009 Im having shifting problems, and i was going to send my tranny to Herr Jugs for him yo do some tranny mods Something about cutting the dog ears or something I was wondering if anyone has had this done and if it helped there problem or not. I do alot of trail riding and trying to leave a override as last resort. So whats the scoup on these tranny mods, do they work or what? thanks Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 4, 2009 Report Share Posted June 4, 2009 Cut every other dog off the trans gears, shift star mod, roller bearing from cascade with the stock roller spring... Just those things will get you a pretty good trans. There are some other mods you can do, but try that out first and see how it does for you. I ran basically that setup on a 10mil cub and didn't have any trouble shifting. - jared Quote Link to comment Share on other sites More sharing options...
FireHead Posted June 4, 2009 Report Share Posted June 4, 2009 Cut every other dog off the trans gears, shift star mod, roller bearing from cascade with the stock roller spring... Just those things will get you a pretty good trans. There are some other mods you can do, but try that out first and see how it does for you. I ran basically that setup on a 10mil cub and didn't have any trouble shifting. - jared Do you know what kind of mods Bonbon has had done while he was turning into a transvestite? :ermm: Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 4, 2009 Report Share Posted June 4, 2009 Do you know what kind of mods Bonbon has had done while he was turning into a transvestite? :ermm: ROFL!! I just spit pepsi all over my table. Thanks mark. Bonbon has 0 trans mods. Bonbon fail. - jared Also, I wouldn't hesitate to send it to HJR for the trans work. Quote Link to comment Share on other sites More sharing options...
wesw Posted June 4, 2009 Report Share Posted June 4, 2009 wacko get with bigred he might be able to hook you up if his 10mm can shift well your 4mm surely would. Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted June 4, 2009 Author Report Share Posted June 4, 2009 Cut every other dog off the trans gears, shift star mod, roller bearing from cascade with the stock roller spring... Just those things will get you a pretty good trans. There are some other mods you can do, but try that out first and see how it does for you. I ran basically that setup on a 10mil cub and didn't have any trouble shifting. - jared Well thats good news than. I havent heard of many people with tranny mods, seems like people go from stock trannys to overrides and thats all. I was hoping some guys that have had it done from HJR would chime in here. What is the roller bearing and roller spring? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 4, 2009 Report Share Posted June 4, 2009 wacko get with bigred he might be able to hook you up if his 10mm can shift well your 4mm surely would. Thanks wes. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 4, 2009 Report Share Posted June 4, 2009 Wacko, BHQ is being gay and won't let me send any more PM's. Jump over on www.dunereview.com/forums and shoot me a PM and I can talk to you some more about what you can do with your trans and where you can buy the parts... - Jared Quote Link to comment Share on other sites More sharing options...
FireHead Posted June 4, 2009 Report Share Posted June 4, 2009 ROFL!! I just spit pepsi all over my table. Thanks mark. Bonbon has 0 trans mods. Bonbon fail. - jared I do what I can to help............... Quote Link to comment Share on other sites More sharing options...
FireHead Posted June 4, 2009 Report Share Posted June 4, 2009 wacko get with bigred he might be able to hook you up if his 10mm can shift well your 4mm surely would. Keep in mind, Jared has two 10mil's to talk about.................. The cub is probably more relevant to this thread. The Twister pretty much has everything under the sun done to the trans. :geek: Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 4, 2009 Report Share Posted June 4, 2009 Im having shifting problems, and i was going to send my tranny to Herr Jugs for him yo do some tranny mods Something about cutting the dog ears or something I was wondering if anyone has had this done and if it helped there problem or not. I do alot of trail riding and trying to leave a override as last resort. So whats the scoup on these tranny mods, do they work or what? thanks I have the same thing done to my tranny. Every other dog cut off and every other webbing removed. Bearing on the shift drum and bearings on both ends of the shift shaft. Shifts pretty well with my 4mil. Nothing like an override but I don't have to worry about backloading the trans either. Doesn't miss shift very often and I can't shift under load. SP Quote Link to comment Share on other sites More sharing options...
FireHead Posted June 4, 2009 Report Share Posted June 4, 2009 Well thats good news than. I havent heard of many people with tranny mods, seems like people go from stock trannys to overrides and thats all. I was hoping some guys that have had it done from HJR would chime in here. What is the roller bearing and roller spring? I would be more than happy to talk to you about your trans. needs as well. Cascade is also a pretty big name in the trans. mod game. Roller bearing: http://67.199.65.66/cascade_innovations/ne...ore_dept_id=165 Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted June 4, 2009 Author Report Share Posted June 4, 2009 I have the same thing done to my tranny. Every other dog cut off and every other webbing removed. Bearing on the shift drum and bearings on both ends of the shift shaft. Shifts pretty well with my 4mil. Nothing like an override but I don't have to worry about backloading the trans either. Doesn't miss shift very often and I can't shift under load. SP So kevin did the mods to your tranny? And yours saying that you still CAN'T shift under a load??? Quote Link to comment Share on other sites More sharing options...
KEVSWS6 Posted June 12, 2009 Report Share Posted June 12, 2009 No, what spurdy is saying is his shifts fine and has a lockout but its no override. I did port his motor but the trans work was already done. Dont worry your in good hands. Quote Link to comment Share on other sites More sharing options...
