4strokekilla5 Posted June 3, 2009 Report Share Posted June 3, 2009 i need to replace the seal but i dont know how to get the shaft out. can anyone help? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted June 3, 2009 Report Share Posted June 3, 2009 i need to replace the seal but i dont know how to get the shaft out. can anyone help? you dont have to remove the shift shaft to replace the seal. remove the shift lever, remove stator cover and use a pick to get the seal out.... :thumbsup: Quote Link to comment Share on other sites More sharing options...
4strokekilla5 Posted June 3, 2009 Author Report Share Posted June 3, 2009 you dont have to remove the shift shaft to replace the seal. remove the shift lever, remove stator cover and use a pick to get the seal out.... :thumbsup: ive tried but i cant find a way to grab onto it Quote Link to comment Share on other sites More sharing options...
Toomey Banshee Posted June 4, 2009 Report Share Posted June 4, 2009 ive tried but i cant find a way to grab onto it I just did mine last month. I just put it on its side, took off the shifter, side cover and foot peg and used a small screwdriver to wedge it out. Pretty easy. Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted June 4, 2009 Report Share Posted June 4, 2009 That's about the easiest way to do it. If you can't get it that way, drain the oil, drain the coolant, take off the clutch cover, and the shift shaft pulls right out that side. Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted June 4, 2009 Report Share Posted June 4, 2009 for fuck sake just screw a few pointed non self tapping drywall screws into it and pull on them at the same time with pliers and it comes right out. If its REALLY in there melt the frikin thing with a torch. Quote Link to comment Share on other sites More sharing options...
4strokekilla5 Posted June 4, 2009 Author Report Share Posted June 4, 2009 I just did mine last month. I just put it on its side, took off the shifter, side cover and foot peg and used a small screwdriver to wedge it out. Pretty easy. well idk why but mines in there pretty good and it wont pull out Quote Link to comment Share on other sites More sharing options...
