bamaboybv Posted June 2, 2009 Report Share Posted June 2, 2009 Got my top end off for a rebuild and I noticed that the left rod/ or stator side rod on the crankshaft has more play than the right side. It doesn't move up and down it just has a little more left and right play than the right/clutch side....Is this normal or should they both be tight? It seems like they both shoul;d hve the same amount of play Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 2, 2009 Report Share Posted June 2, 2009 Got my top end off for a rebuild and I noticed that the left rod/ or stator side rod on the crankshaft has more play than the right side. It doesn't move up and down it just has a little more left and right play than the right/clutch side....Is this normal or should they both be tight? It seems like they both shoul;d hve the same amount of play They should be equal but the clymer's manual will give you the specs for rod end play. SP Quote Link to comment Share on other sites More sharing options...
