Crank ?
So I'm doin a rebuild and I have my cylinders being ported with an aggressive trail port. I had to get another crank because the rod bearings on my old crank were bad. This new crank is off a low hour 04. Everything on it is clean and tight. All you guys with slightly modified motors have welded and trued cranks??..I don't wanna take this bitch out and blow it up from the crank exploding. Thanks Michael
i'll ask my buddie who tig's and i will pm you tomorrow.
You have to have a degree wheel to true the crank ....then in most cases the outer pins are welded.
unless you get a rebuilt crank like mine and the person that rebuilt it welded the inner pins as well which makes it even stronger yet.
Dan
I can turn your crank around same day if you need ....
